October 27, 2025, 10:51:04 AM
Yamaha G100 112 - Transformer?
Started by dlbraly, July 14, 2018, 09:38:42 PM
dlbraly
Hello Y'all,
We picked up a Yamaha G100 112 first series.
Ive been trying to figure out what exactly should be coming out of the transformer.
When I measure across the 2 brown wires I get 29.3 VAC.
if I measure from the black wire to either of the brown I get 14.3 VAC
if I measure across the 2 red wires I get 73.1 VAC
Is that normal output?
Just curious, what is a good replacement for it?
This was my first post here. I have a lot more questions.
Can you post a schematic?
I rarely wonder about transformer voltage unless one is missing or super low.   What leads you to suspect the transformer?  I mean what is wrong we are trying to fix?  Those look like real reasonable voltages to have.
dlbraly
Hello Enzo
The biggest reason is curiosity, I have no idea what readings I should see.
Problem - the amp is not as loud as you'd expect a 100 watt amp.
having the volume up past 5 was not excessive loud. and having it on 10 was loud, but bearable.
The distortion channel is a lot less.
I have not posted more questions yet, because I found a bad transistor that I want to replace. I removed the part and tested it on one of those LCR-T4 Tester.
2SK30A GR
Im not sure if I should order that part, wait for it and see if that fixes the issue, or start checking parts on the MA board.
Ive been reading your posts Enzo - Thank you so much for being active here and helping people. Im enjoying reading your posts.
https://www.ssguitar.com/index.php?topic=3815.0
I am novice, and want to learn more. This amp is my Dad's he picked up off craigslist. I wanted to fix it for him. I also bought a Fender amp that has issues, that I will be asking about after this one.
A 2SK30 is not a bipolar transistor, meaning it does not have emitter, base, and collector.  You can't test it like a bipolar.   It is a JFET - junction field effect transistor.  With an ohm meter, two of the legs will show a lowish resistance, and the third leg will be the gate and act like a diode towards the other two.
dlbraly
Thanks, I kind of figured that out plugging the components into the LCR-T4 Tester.
That tester is pretty cool.
it tested the other 2SK30 just fine, but this one failed.
Attached the schematics
If the 2SK30 in question is 1/2 of the input LTP circuit, I would replace both of them.
