The Big Heavy Elephant 🐘 (in the room)
Started by saturated, Today at 07:45:45 PM
saturated
I've had this probably about five years
It's a big Bud Radio box with a DIY (unknown persons) DC power supply.
It has selenium rectifiers, rigid varnished wire, two big capacitors, a very heavy choke and a weird eyelet board containing a big diode and resistors and (TO-39?) transistors and capacitors
It does not have (and apparently never did) a transformer  xP
And of course no it won't even be considered attempted to fix without one.
Anyhow here are some pics the big caps and choke are not presently attached
Oh look it's a convertible  xP
The chassis slides out the front
The back is open for the convenient storing of illicit items
The topside of the circuit
And the bottom
The big caps
Speaking of Mallory...this is gonna be difficult enough for me but whatever is going on on that eyelet board is gonna be my personal Mount Everest  :'(
I think nothing is going to happen until I can translate these physical objects to a two dimensional facsimile aka schematic and attempt to make heads or tails of it
That being said I may jumper the caps or not maybe they are just parallel idk and jumper the choke connectors and feed it low voltage AC from a transformer like six volts and see if it has any output whatsoever
Welcome to ssguitar.com
Where YOU become the PRO !
saturated
Alright well the obligatory "no way this works but we have to try it anyway" yielded some surprising results  :tu:
It took me a while to remember the insulating varnish  xP
Everything hooked up
Meter on left measuring transformer secondaries
Meter on right measuring DC output (if there is any)
And here we go
Oh crap  :dbtu:
Who knows how bad off this thing is but that was surprising to say the least  xP  :loco
And those alligator clips don't connect well to small wire
The DC was definitely jumping around a bit
Also the big green bulb never came on
I had a difficult time trying to guess which way the toggle switch was on or off
And same with the rheostat  xP
