Help with transistors
Started by Den., April 26, 2026, 04:28:17 PM
Den.
Hi... I'm looking at a Bose L1 model II PA amplifier and I'm looking for help in interpreting a series of voltage measurements. There's a pair of what I think are transistors that look suspicious. On the diode mode these are the readings I got. Can someone help me? Thanks.You cannot view this attachment.You cannot view this attachment.
galaxiex
Those look like voltage regulators.
Clean the schmoo off the top where the "L78" number is so we can read it.
That is likely the part number.
U115 Volt Regulator -15V L7915CD2T  D2PAK  ST
U116 Volt Regulator +15V L7815ACD2T D2PAK  ST
Service Manual:
https://studylib.net/doc/27942375/l1-model-ii-service-manual?p=32
