Realistic MPA-100
Started by saturated, October 26, 2025, 09:49:38 PM
saturated
Time to play with this one
Had to borrow a fuse holder cap and a fuse and put it on the big ugly DBT with 60w bulb
Next input signal 1Vp-p and hooked scope probes to input and (16 ohm) output
Input channel one and output channel two
Amplifier power off (ch 1 at the bottom)
Next amplifier power on and had aux volume at half and master volume at half
Not much amplification going on  :grr
Next I tried to max out both volumes and see the result but it started flattening out the top of the output
The most output I could get is about four Vp-p
 xP
Now...granted there are a bunch of switches on the back so who knows
And...idk what I'm doing  :'(
So there's that but it looks like it works to me idk  :lmao:
One really wierd thing that happened...I could hear a very faint hum with the power off.  I leaned in to listen better and thought wow is that my 1 khz signal ?! So I reached up and changed the frequency and yes it was my signal I could hear it with the amp power off  :loco
Here in 1994
saturated
I'm gonna propose that the above is probably not SOP for amp testing  :tu:  :loco
I'm gonna connect a speaker and see if I can get ear bleeding 1 khz  :tu:  :lmao:
Here in 1994
saturated
Alright well either
-im not doing this correctly
-or this amp is putting out one watt  :lmao:
So I -connected an 8 ohm speaker
-Scope leads across speaker terminals
-Maxed out aux and master volume
-increased signal until output started clipping (about 2.8 Vp-p)
Did math
 :grr
So I guess I have a sick one here  xP
Meanwhile it cut off a few times I could hear a distinct click whenever it did.  It was not intermittent it wouldn't come back until I turned it off and turned it back on after s moment.
And the fuse is good.
I guess that explains why all the cover bolts were missing
A couple things I noticed about this amp is there is no relay click maybe it's not supposed to have one because it "works" with out it.
Also I noticed the bottom panel gets warm
 but I saw a video pointing out that the output transistors are attached to the bottom panel
So right off the bat I suspect a bad voltage regulator  :lmao:
Here in 1994
saturated
I was becoming suspicious of this guy
albeit for no reason I just figured it looks like it gets hot and may be failing.  But then I figured it's probably not a voltage regulator since it's marked ECB and TR 201
Might be time for some freeze 🥶 spray since it seems like something is getting hot and shutting down.
Here in 1994
saturated
Hmmm
Seems like some more stuff to learn
https://www.ssguitar.com/index.php?topic=4594.30
Specifically (per G1)
"I'm not sure your test set-up, but it's critical that you do not ground the speaker (-) with any test gear, grounded load, etc."
(I was clipping my scope ground to the negative speaker terminal).  :grr
Here in 1994
The thing about not grounding the load is pretty much specific to amps that use current feedback and amps that operate in 'bridged' configuration.
This one is probably not either, but no harm in moving the scope ground to chassis, that is usually the best place for it anyway.
Any time you see a heatsink or a high power resistor, expect heat.  So I expect that TR201 to get hot.
In older stuff, they did not have dedicated voltage regulators so they used regular power transistors in a regulation circuit (often 'pass transistor' topology).
Check the DC readings on it's pins, that may give an idea of what it is doing.
You may be in for a bit of a rodeo with this one, having no schematic.  ;)
I have located a schematic for the MPA-201.
As it is a dual channel amplifier you will have to take anything on it with a grain of salt.
The power amp looks as it may be the one that you have.
Although the component designators will most probably be different.
The regulator circuit appears to be a simple 15 volt zener diode.
saturated
Thanks guys  :tu:
I know it's not much but in the meantime I still need to do stuff so I think I will try to flip that board over and reflow TR 201 (or remove and test and attempt to identify then reflow )
Also I can remove that green capacitor that looks cracked  :grr and try to see if it has any markings on it so I can replace it.
I left it on with signal last night for about an hour and it would modulate for a while then cut out then after being quiet for a while it would come back on then repeat.
So I'm guessing that something is heating up and shutting down then cooling off and doing it all over again.
Also I noticed one of the binding posts somebody unraveled it but put it back.
xP
Here in 1994
saturated
So I'm in a pickle trying to invert this board to desolder TR 201 and that cracked green (poly film?) capacitor
These two sets of wires are attached to the chassis
The bundle on the left looks doable since it had a nut and bolt 🔩
But the bundle on the right was adhered with silicon ? and it started to come loose and I'm wondering what this is  :grr  :loco
But wait there is a clue
I need to find out what this symbol indicates
 :grr
Here in 1994
The symbol is a thermistor.
J5 & J6 on the output section of the schematic.
saturated
Ok I got these guys out
Pinout same as PCB markings
Idk if this means it's bad or weak
Not sure what to make of this or how to identify
Here in 1994
Most Japanese transistors like that omit the '2S' prefix.  If you see a transistor with just A,B,C, or D in front of a number, that is usually the case.
So what you have there is a 2SD569.
dmeek
For what it's worth, here is a partial schematic I made the last time I saw this model.
saturated
Thanks guys I appreciate I have to put forward that since I so greatly appreciate your help I have to let you know this is for all essential purposes a cadaver that is being worked on and not something I desperately need like working for my son on Christmas day or something  :dbtu:
With that said let's carry on
I may have found a replacement for TR-201 but I'm in a little over my head with the ratings
Idk if it ( Toshiba TT015B) will be able to endure the rigors of the environment
Here in 1994
saturated
Meanwhile here is what I think for the capacitor
Found what seem to be some suitable replacements but not sure what voltage rating I need
Might be some info in the schematics kindly provided so I'll take a look
Btw wasn't sure if 334K means 334,000 picos or not
And with that I'm gonna try to get out of y'all's hair I appreciate the help I reckon y'all have much more important stuff going on  :dbtu:
Here in 1994
