Voltage divider mania
Started by saturated, September 15, 2025, 06:17:07 PM
saturated
I decided to do an experiment looking at resistance ratios and see if it held up in real life.
I started to acquire resistor pairs of 10:1
then apply voltage and check voltage at the node
Results
I'm impressed with the results and attribute any variances to the resistors used.
For some reason the 100 ohm resistor died.
 xP
Consumed by negative voltage ⚡
