Dude..... where's my voltage
Started by saturated, August 29, 2025, 04:16:59 PM
saturated
So I think I built my first amplifier
Is it clear now  :lmao:
I input a one khz signal and measuring at the collector I get amplified voltage ?
But it's out of phase so measuring at the emitter it's in phase but I lost all my voltage
 :grr  :-X  :'(
And I know there's reasons for all of this so I'm off to learn about it.
I have a suspicion calculating and looking at the voltage drops and voltages will explain much of it.
 xP
Consumed by negative voltage ⚡
Yes, 6X gain (6.8/1)
That´s a classic transistor gain stage; my classic go-to value with 10k load  is 3M3 bias or for 3k3 or 4k7 load,  1 M bias.
Works all the time with almost any transistor.
Gain is load resistor value divided by emitter resistor value.
Works fine up to 50X gain, go figure.
Back in the day I published in a Magazine a series of projects based on these. from a single transistor Guitar booster up to a 6-8-12 channel mixer.
Lots of people built them and a few work to this day.
saturated
Senor JMH mucho gracias for accompanying me on this venture.
  I have some more snacks for you amigo  :tu:
I was to calculate then measure the maximum peak to peak output voltage by increasing input until clipping occurred
So I did it maxed out about 20 Vp-p
Any slight increase and ...
This reminds me of you big dogs 🐕 telling people to adjust trim pots ?  until clipping occurs
Anyhow Happy Labor Day everybody  :tu:
Is the input capacitor installed 'backwards'?
saturated
Yes sir thanks idk
I struggled with the orientation and looking at the schematic I did not know what the curved line of the symbol indicates but after some research I thought it was supposed to be the negative terminal
 :loco
Yes, curve is negative.  Looks like base is positive so I think cap is shown correct on schematic.
Maybe Jazz was wondering about your wiring?
