Randall RG1003 issues changing channels
Started by anderson4584, July 10, 2025, 10:56:55 AM
anderson4584
Hello,
I bought a used RG1003, that is VERY clean and works great, with the exception of changing channels using the footswitch. Hitting the channel buttons on the amplifier works fine. I received the amp a few days ago, and it seemed to work fine. Then out of nowhere this issue started happening. I can always change to channel 3. But I have issues getting it back to channels 1/2. I opened up the footswitch and everything seems fine in there. I played with the wires a little bit to see if it would change anything and the only thing that changed anything is.......it typically works fine when I hold the footswitch upside down. When this issue happens, I also typically lose a lot of power output while playing, but ONLY in the bridge pickup. If I switch to the neck pickup, I get power back. This does not fix the footswitch issue, but they seem to go hand in hand.
This issue in general is not always present, but it's happening all the time. I can play for a bit without it, then it just happens.
What I've tried:
-Cleaning contact by spraying the footswitch input and plugging it into the footswitch jack on the amp.
-Tried using another 2 switch footswitch I have that goes to a Peavey classic 20MH (this works... but it ends up having the same issue, which leads me to believe it's the amp).
-Swapped some cables around, and tried different guitars.
Any ideas?
This footswitch needs to have momentary switches.  It sounds like yours may have latching type switches.
Quote from: anderson4584 on July 10, 2025, 10:56:55 AMI can always change to channel 3. But I have issues getting it back to channels 1/2. I opened up the footswitch and everything seems fine in there. I played with the wires a little bit to see if it would change anything and the only thing that changed anything is.......it typically works fine when I hold the footswitch upside down.
That makes no sense.
Do you hold pedal in your hand or put in on the floor? (so floor can push both buttons at the same time)
QuoteWhen this issue happens, I also typically lose a lot of power output while playing, but ONLY in the bridge pickup. If I switch to the neck pickup, I get power back. That makes even less sense..
QuoteTried using another 2 switch footswitch I have that goes to a Peavey classic 20MH (this works... but it ends up having the same issue, which leads me to believe it's the amp).
For testing, plug a spare TRS/"stereo" plug in theb Fsw jack.
Cover open, pins visible.
Solder a short (1" to 2") piece of wire to plug ground terminal.
Then touch either of free pins (to simulate temporary switch) with the free end ... what happens?
Repeat test but now soldering wire end to a pin or another to simulate a latching switch.
This way you are testing using a bare minimum "pedal equivalent" device, very simple and easy to understand, which depends on nothing else.
Post results.
Any ideas?
anderson4584
#3
Quote from: J M Fahey on July 11, 2025, 03:02:08 PM
I know... it's TOTALLY insane.  So it was doing it when I held it in my hand.  I've since rested it on the desk my amp+cab is on upside down and I just press down whichever side I need.... and it totally works.  It TRULY makes no darn sense.  It is NOT pushing both at the same time. I make sure of that.
I know. I've never come across anything like this. I got all weird and started swapping guitars thinking it was an issue with my guitar.  Nope same issue with other guitars.
Post results.
I am at work and about to leave. I'll try this as soon as I can, but I have family over.  So it may be a few days unless I can manage to find time to do this while they're here. Thank you for your time.  I'll come back with results one way or the other.
