Suggestions for Bass/Guitar preamp to pair with TDA8932B P.A.?
Started by blackcorvo, June 30, 2025, 02:09:48 AM
saturated
I thought it was killer  :tu:
Almost heard a little N.I.B. at 5:27  <3)
Here in 1994
saturated
It started out like geddy and ended up like geezer  :dbtu:
Here in 1994
blackcorvo
I was perusing this thread on DIY Audio about the chip amp I'm using:
https://www.diyaudio.com/community/threads/fasten-seat-belts-tda8932-pessimistic-review.277130/
And people there mentioned cutting out issues related to overheating and over voltage, so I got adhesive heatsinks to see if it'd help.
Nothing.
I then tried using a variable PSU I have to see if a stable 12v or under would work.
And... For a moment, it did. Even got a bit overdriven in a nice way.
But as soon as I tried recording, it stopped and went right back to cutting out.
So I'm completely clueless to what might be causing this issue.
I think I'll just put a TPA3118 in there and call it a day, as I've had no issues with that amp in the past. I even have one in a repurposed modem case, that I use as a PA for testing pedals and preamps.
For now, I'll give it a couple days to see if anyone else has any idea of what I might be missing.
[Edit]
One last thing I might try is adding soft clipping at the PA's input.
https://sound-au.com/articles/soft-clip.htm
She/they since August 2021
Quote from: blackcorvo on July 17, 2025, 07:24:07 PMI was perusing this thread on DIY Audio about the chip amp I'm using:
Nothing.
[Edit]
How did you try to add a heatsink to that amp ?
Many of the modern low power D class amps use the PCB as a heatsink, the IC has a heat pad on the bottom of the IC that touches the PCB.
Often there are a hole bunch of vias or sleeved holes under the IC to transfer the heat to the bottom surface of the PCB which is flood filled with copper to provide a heatsink, in that case it might be best to place a heatsink under the PCB with some insulating double sided tape.
It might seem strange that you don't place a heatsink on the IC itself but if the heat is being directed down and through the PCB itself then the heatsink has to live on the back.
I don't know if your amp needs the heatsink on the IC or on the back of the PCB but it is something to think about, feel the IC and the back of the PCB as the amp is heating up.
Cheers
Mick
blackcorvo
Quote from: Tassieviking on July 18, 2025, 11:02:52 AMHow did you try to add a heatsink to that amp ?
I got 3 packs of the RPi heatsinks, 1x 14mmx14mmx5mm and 2x 9mmx9mmx4mm per pack, and put 2x of the 14mm under the board right under the IC, and 2x of the 9mm on the chip itself (just to be safe), but nothing seems to have changed.
I'm just grasping at straws here tbh.
Just to see where the chips fall, I would test once more the chipamp, driving it straight from generator or at most a 1 Op Amp low gain stage, say 3X to 10X tops if beyond what the generator can supply, and from a simple power supply, not boosted batteries or regulated supplies but transformer - diodes - caps.
Nominal 12VAC will give you some 15-16V DC
The point being to confirm the amp itself fails and not Preamp or supply throw the towel.
Did you scope the +V rail to see if it drops?
That click click click may come from amp protection but also from supply protecting itself.
*In theory* TDA8932 should work fine for that load and supply ..... in practice, who knows?
But if so, stop using it, period.
TPA3118 has a reasonably proven record so far.
blackcorvo
I was using the batteries directly - unprotected batteries, too - for my tests, so power was very clean, and saw no voltage drops with signal. And I tried the preamp on a separate power supply, both with the PA on it's own PSU and on batteries - same cuttting out result.
Also, just as an "insanity test", I went reading up on the DIY Audio thread again, and it seems like TDA8932T has presented issues for other people too, and they had better luck using the BT variant of the chip instead. Some mentioned having better performance with it running from 12 to 14v, and the one time it stopped doing the cutting out thing for me yesterday was when it was being fed around 11v. Then after a power cycle, it did it again.
I'm starting to think this chip or board has some manufacturing defect...
Maybe.
To make certain, get a TPA3118 board and use it the same way you are using 8932 now.
No need to order from China and wait, just get one at Mercadolivre, even if slightly more expensive.
What city are you in?
If in SP, Multicomercial and shops in Sta Ifigênia have anything you need.
Just an insanity check: remember speaker leads must *both* be floating, no speaker terminal can touch ground.
If you use a speaker jack in a metallic chassis or cabinet (many put those amps inside a Hammond type pedal box) then you NEED a plastic jack (Cliff/Marshall/Vox type), not a metallic one (old Fender type).
Measure DC to ground, no signal, at each speaker out lead, both (+ and -) must measure 1/2 +V
Recheck: with amp OFF, measure DCR to ground at each speaker terminal, when connected to amp.
blackcorvo
So, new development: could be a grounding issue.
I removed the limiters and went back to the base circuit for the preamp, and discovered that once I grounded the circuit to mains ground (and added a 68k series resistor between preamp out and PA input), I could go to full volume without it cutting out.
This is really weird. An amp that doesn't like not being grounded to an outlet.
Don´t you have a scope?
To distinguish between bursts of oscillation, protection chopping audio, DC jumps, whatever.
Ear alone is not enough.
blackcorvo
I had a DSO138, but it broke ages ago and I never got around to get a new one.
But now that you mention it, I looked and found a DSO152 I could get (30 bucks). I'll see if I have enough in my account haha.
Also I forgot to mention, but I had already ordered an extra TPA3118 alongside those heatsinks.
Update: the DSO152 gets here on Monday.
Also one last thing I'll try is adding a pair of diodes to isolate the preamp from the PA (both anodes to battery V+, each cathode to the V+ of each circuit).
blackcorvo
Project chugging along, doing a few more tweaks to the build: added BMS boards for each battery pack, and soldered the isolation diodes, gonna try to finish it today after work, so I hadn't had time to test it with the 'scope - which did arrive, and works great from what I tested so far with the function generator app on my phone.
Also ended up finding the old one, and sure enough it's busted, not showing a wave regardless of what signal I inject into it. No idea the cause.
Last but not least, one of the buck converter boards I was trying out let out the magic smoke. Shorts happen.
blackcorvo
Last week was a bit hectic, and I got a throat bug on the weekend, but I managed to do this quick test just now to show exactly when it's cutting out, and I think my main issue is the batteries. I wish I could use them but it seems they just can't handle the load.
Got plenty of power from a power supply.
BTW I'm using a XL6009 buck converter to get 25v for the P.A. here.
FWIW I never ever use a buck converter to go *up* in voltage, the stress on the low voltage side is huge.
I DO feed amps higher voltage rails from 12V 7A lead acid batteries but:
* do not "buck" anything but use heavier duty voltage inverters.
More complex/heavy/expensive but the real thing.
What car power amps use.
* lead acid batteries have HUGE current capacity, that´s why they are used to start car engines.
blackcorvo
Yeah I'm not interested in getting completely new batteries for this build. I'm already pretty much outta funds as is haha! Also I got a whole drawer full of 18650s I wanna use. I'll probably just drop the integrated battery idea and instead build an external pack that plugs into the power input plug instead.
