New forum member; looking for a primer for SS amp work.
Started by carlsoti, June 20, 2025, 08:07:22 PM
carlsoti
Hello all. I'm new to the forum and SS guitar amp work in general, but I built my first tube amp in the 90s as a teen, cut my teeth working at Rockford Fosgate/Hafler around the turn of the century, and have been doing tube amp and guitar effects repair on the side off and on for a while.
I'm looking for some sort of primer for how to diagnose a vintage SS Sunn Studio Lead amp so I don't have to pull ALL the transistors to test them.
The amp came to me with the complaint of "it only hums." I found that the caps were all original and the output cap had puked it's guts out. Against my own better judgement, I shotgunned all the electrolytics as the originals are all older than I am, and as one might expect, it did NOT fix the issue. The output transistors test good on my Peak DCA55. Voltages in the power supply seem to be more or less in the ballpark with the power transistors removed. I have a crappy USB Hantek O-scope, but it's been uncooperative since I moved recently.
If anyone could point me in the direction of some sort of primer on how to proceed without simply pulling all the transistors to test OOC, I'd greatly appreciate it.
T.I.A.,
Tim C in AZ
Well how about some voltage checks on the transistor legs? Personally I never pull a transistor unless it's dead or very questionable. I do chuck old dried up electrolytics in the garbage. Voltage checks and tracing signals are your best bet. A good transistor may never work if you have a cracked trace in the circuit board. What part of AZ are you? I'm in Scottsdale 👍
Since it was not blowing fuses, you can put the output transistors back in.
Like DrGonz said, voltage checks are the best way to proceed.
Since it has an output cap, it will be AC causing the hum, not DC on output.
You can disconnect the speaker if the hum is too annoying, and measure the AC volts at the output.
Schematic available here:  https://www.ssguitar.com/index.php?msg=16694
carlsoti
   Thanks for the replies, folks. Sorry for the incredibly delayed return to this post. This amp got shelved for way too long and now I'm stumbling my way through it again. I shoulda cut bait early on. In short, this old Sunn Studio Lead amp just hums and no signal passes to the speakers. The output transistors test good on my PEAk teater and all electrolytics are new(ish.) I'm generally vehemently against shotgunning parts, but the electros were all older than I am, and I've been getting AARP ads for a few years now.
  I think I've discovered one of the reasons that tube geeks hate working on SS amps. Having to scan between the layout and schematic for the appropriate places to probe, in addition to needing to have a half dozen different datasheets open to ensure the proper leads are being probed is a p.i.t.a. when I'm used to knowing what's going on around a tube socket by memory and rarely need to verify the PCB trace paths with vinage hollow-state gear. In addition to that, I really don't understand the function of all the transformer sections of T2.
  With that said, it seems I've got excessive voltage at the second node. Around 47V at the first and 45V at the second. IIRC, around 25V on the third PS node. The first and third seem to jive with the increased mains voltage over the years, but I would've guessed that the second node should be around 40V. This would lead me to believe something around that node is not passing current. (Also of note, I have something like 17V AC ripple at the first node. That seems like a LOT for such a low voltage power supply. Could it be that a bad bridge is clouding the process?)
    I suspect I'll have to probe around Q104-Q106. Without reference voltages, how do I make the determination between an active component failure and the T2 transformer being hosed, which I read here is a "common" problem, despite a lack of relavent info regarding the Sunn Studio/Stage Lead amps?
    I really don't understand why this is flummoxing me as much as it is. I can debug oddball vintage EHX and mutron pedals without nearly this much anguish. It could be an unreasonable fear of an avalanche style failure, or maybe the fact that I can't probe all the transistors IN the amp, without removing the PCB or cross-referencing all the parts to find a suitable test point. The stupid little "suports" prevent me from probing the transistor legs directly. A nudge in the correct direction would be greatly appreciated.
 P.S. I'm in Tempe, Dr. Gonz.
Kaz Kylheku
Quote from: carlsoti on July 31, 2026, 01:32:45 AMI suspect I'll have to probe around Q104-Q106.
The problem is no signal through the amp, right? Q104 is a good place to start a binary search; it's the start of the power amp.
Use your USB scope to see whether the input signal is reaching the base of Q104.
Ooh, this is a quasi complementary output stage (both output devices are NPN). They are using the T1 as a phase inverter, because for the output stage to swing low, Q1 must be turned on by a positive swing, not a negative one as would be the case with a complementary stage with a PNP on the bottom.
In some vintage solid state amps, you also see an even more tube-amp-like approach where the phase inversion is done by a transistor circuit, but then a center-tapped output transformer is used after the two NPN transistors to combine their output, just like in a tube amp.
It seems the designers here wanted the tone to be shaped by an output transformer, but they decided to make it a smaller one and put it before the output stage, and when you do that, you can kill the phase inversion problem with the same stone.
If the base of Q104 has signal, check that the T1 transformer isn't blown: the schematic gives the resistances that the windings should read.
It looks like the only thing running off the 38V node is Q106 which drives T1.  Any fault in the Q106 circuit (open R130, bad Q106, open T1 primary) would mean no current drawn off that node, and no audio output.
Quote from: Kaz Kylheku on July 31, 2026, 02:34:33 AMIt seems the designers here wanted the tone to be shaped by an output transformer, but they decided to make it a smaller one and put it before the output stage, and when you do that, you can kill the phase inversion problem with the same stone.
This type of design goes back to before anyone cared about sounding like tube amps.  Complimentary power transistors and electronic parts were very expensive relative to mechanical type parts like transformers, so I think it was mainly about cost.  Transformer driven quasi-complimentary output stage was not uncommon in early solid-state audio.  Some of the early Yamaha amps used it (TA series for example) and I think early solid-state car radios as well.  JM Fahey has commented on the design before and knows more about the history and usage.
Kaz Kylheku
Quote from: g1 on July 31, 2026, 11:31:08 AMThis type of design goes back to before anyone cared about sounding like tube amps.  Complimentary power transistors and electronic parts were very expensive relative to mechanical type parts like transformers, so I think it was mainly about cost.
BTW, I just found, the solid-state Fender Twin Reverb from the early 70's has pretty much the same architecture: the transformer with complementary secondary windings acting as the phase splitter for quasi complementary output stage.
carlsoti
    I've started digging deeper into this amp. I'm having some difficulty finding the datasheet for the "FSE-4020" transistors at Q104 and Q105. I've searched "Fairchild SE-4020" and every other permutation of FSE-4020, but it seems this device is something of a ghost. I figured I'd try to ID them by the tiny little logos sometimes found on the device, only to realize that ALL the TO-18 devices are the same part number, BC107B, as used in Q101-Q103. I can compare datasheets and make decent guesses re: parts substitutions, but without the sheet for the FSE-4020, I'm dead in the water. I'm not well versed enough in SS design to know if a BC107B is suitable as a replacement in this circuit as drawn. Sure, it's NPN, but beyond that, IDK what's appropriate. Any insight here would be appreciated.
    Additionally, I've verified that all the windings, end-to-end, are good in the "T2" transformer, though I did forget to check for shorts between windings. I'll do that momentarily, before starting to pinpoint voltages for ALL the relavent points throughout the amp. I'd really prefer to avoid signal tracing without having found a resolution to the constant hum, but I'm prepared for that eventuality.
carlsoti
#8
The issue "might" be a sketchy TIP30B in Q106, as suspected. Though, aside from high voltage at the second node, and what seems like really low gain out-of-circuit, there's no dead-giveaway. When tested with my DCA55, it gives the HFe at "6" and I'd expect at least double that, but IDK. It could be an issue with the BC107Bs in Q104 and Q105. Really wish I knew what those FSE-4020 transistors were.
I'll try to attach the voltages I read throughout the amp. Signal tracing seemed "ok" up until I got around the transformer section, as one might expect. I couldn't track the actual amplitude of the signal, as my environemnt is noisy and my USB O'scope is trash and has minimal support from Hantek.You cannot view this attachment.
If you see anything obvious to you, please let me know. I guess I'm deep diving to figure out what the FSE-4020s are, and if all else fails, ordering a new TIP30B for some more shot-gun/spray-and-pray repair work.  :-[
carlsoti
I found a discrapancy between the available docs and this amp. I don't think this change would influence the problems exibited, but for the sake of documenting this amp correctly, I've attached the change in a snippet of the layout and shcematic.
Kaz Kylheku
Yes, it looks like Fairchild had a SE-4020 transistor, which is listed in this 1973 catalog.
Some basic parameters are given in a table on page 3-30.
The circuit in the schematic is a bog standard differential stage that is not critically dependent on choice of part. I think, because it doesn't use any active loading*, it relies on the transistors having decent gain. The Fairchild part had decent Hfe figures for the time (having to do, evidently, with Fairchild having invented the planar process). A modern part like a 2N5089 should work there.
* Active loading a technique where a load resistor like R129 in the schematic is replaced by a current source. The gain of the stage depends on that resistor: the transistor below varies the current, and Ohm's law on R129 translates that to a voltage. Active loading replaces the resistor by a current source (built using another transistor). A current source looks like very high resistance, so the gain is greatly multiplied. In long-tailed pair differential stages, you also often see a current source used the tail resistor position where the Sunn just has 4.7 kΩ resistor R131.  A stiff current source in the differential stage's tail improves the performance in a different way: it drastically reduces the common mode gain (the unwanted amplification that occurs when the same voltage is applied in lockstep to both transistor bases) thereby improving the CMRR.
carlsoti
Quote from: Kaz Kylheku on August 03, 2026, 12:59:18 AMA modern part like a 2N5089 should work there.
In that case, the BC107B parts currently in there should be suitable, correct? I did select the two with the closest gains to put back into that portion of the circuit.
Which leaves me eyeing that Q106 transistor, the TIP30B, that seems to give about half the gain of expected. I've got a TIP42C around somewhere which, if I can find, I'm going to try in circuit. It's a bit beefier than the original part, but it'll give me something to do while I await a TIP30C and/or some sort of divine intervention to help me sort this out.
Again, thanks to all that have helped usher me through this project.
carlsoti
   If there's a trope about tube amp techs being too lazy or not thorough enough to be competent SS techs, I might embody that trope to the Nth degree. I seemingly tried every trick I knew to work through this one.
   Q106, the TIP30B driver, was the only device that was soldered directly into the PCB, making it a "pull the whole board" job to test out of circuit. Once out of circuit, it STILL passed all the basic tests, but the gain was SO low. A new part arrived this afternoon and tested about 20x higher gain that the device I pulled. Dropped it in circuit and everything else fell into place. As one might expect, this Sunn is loud, clean, and relatively noise free.
Thanks again, to all who offered assistance.
Quote from: carlsoti on August 07, 2026, 09:55:21 PMIf there's a trope about tube amp techs being too lazy or not thorough enough to be competent SS techs, I might embody that trope to the Nth degree. I seemingly tried every trick I knew to work through this one.
Oh , don´t be so harsh on yourself.
Fact is Tube technology was already mature and stable over 70 years ago, in the 50s, so if you understand and can repair a classic Fender amp, which can be repaired without schematic if needed, you basically can repair ALL Tube amps.
To boot, other makes basically clone a Fender, more o less. which narrows the field even more.
No such luck with SS ones, which keep changing, even today.
QuoteQ106, the TIP30B driver, was the only device that was soldered directly into the PCB, making it a "pull the whole board" job to test out of circuit. Once out of circuit, it STILL passed all the basic tests, but the gain was SO low. A new part arrived this afternoon and tested about 20x higher gain that the device I pulled. Dropped it in circuit and everything else fell into place. As one might expect, this Sunn is loud, clean, and relatively noise free.
