Peavey Muscian 400
Started by aoresteen, April 08, 2025, 06:12:05 PM
aoresteen
I am tracking down information on the Peavey Musician amp 400 series. I bought one new with the Peavey 410 cabinet around March 1974 and used it until June 1977 when I sold it. It was too loud (140ish watts into a 4 ohm load) and I was tired of hauling it up to our 2nd floor apartment.
I decided to track one down and use it in my studio.  I plan to make a couple of mods to the amps.  To my surprise, there are three versions of this amp.
Version 1 (Mark I)
This one does not have the Master Gain/Reverb knobs. It does not have Parallel/Serial inputs.
The foot switch has a DIN 3 pin plug. Per the schematic, the foot switch has three foot switches.  It appears in the Peavey 1973 catalog.
Peavey refers to the Mark I as "A Series". This label is found on the amp schematic.
The user manual is on the Peavey website, Archived Manuals, under the M section as "Musician".
Version 2 (Mark II)
This one DOES have the Master Gain/Reverb knobs. It DOES have the Parallel/Serial inputs.
The foot switch uses a 7 pin DIN plug and it has 5 foot switches. Peavey refers to the Mark II as "B Series". This label is found on the amp schematic.  The user manual is NOT on the Peavey website.
Version 3 (Mark III)
The Mark III Musician has the Peavey Mark III series design:
I do not know what kind of foot switch it uses. All the manual says is that it uses a "DIN" plug.
The user manual is on the Peavey website, Archived Manuals, M, as "Mark III Series Musician".
1.  Where should I put an Effects Loop connectors for the Mk II model? The schematic is HERE .
2.  What is the best place to put a master volume control for the Mark I model?  The schematic is HERE
3.  Does anyone have the user manual for the Mark II Musician?
4.  Does anyone know the dates of introduction for any of the Musician models?
Thanks!
Tony Oresteen
Peavey Bandit Silver Strip, Revolution 112
Marshall MOSFET Lead 100 3210
Fender Frontman 25R 2010ish
Newnan, GA
