November 08, 2025, 09:00:09 PM
Swapping TDA2050 for LM3875 in Vox Cambridge 30
Started by stk, August 20, 2007, 06:59:38 PM
stk
Hi all. I have a Vox Cambridge 30 Twin Reverb. This amp has a TDA2050. I've read about people replacing the TDA2050 in this amp with an LM3875/LM3876/etc. Example:
http://voxman3.tripod.com/BobAmpPage.htm
I'm thinking about doing this. Anyone done this or know the motivation behind it?
I checked the TDA2050, and it's getting 28V right now. I think that may be too much for it, and hence why the LM3* chips would do better in this circuit. It seems odd to me that Vox would build them this way, but maybe I am missing something?
Supply voltages are definitely past the max ratings of the concerned TDA chip. Reputedly that amp will also suffer from problems with the optocoupler.
stk
Quote from: teemuk on August 21, 2007, 04:47:25 AM
Thanks for the reply. The optocoupler has already been swapped in this amp. I rechecked the voltage to be sure and it is still at 28VDC. I'll go ahead and put an LM3875 in it and see what happens.
