Five legged critter in a crate
Started by saturated, December 24, 2024, 02:00:42 PM
saturated
Noticed this in a trash 🗑�🚮 picked Crate
After a little research maybe it's possibly a TDA2030 or LM1875 ?
 :loco
Here in 1994
Quote from: saturated on December 24, 2024, 02:00:42 PMAfter a little research maybe it's possibly a TDA2030 or LM1875 ?
TDA2030 was what I was thinking as well.  Here is their G10XL schematic which may be similar.
saturated
Well guys I decided to play around with this amp  :P
I thought it would be cool to try and fix it.
Unfortunately it works  :grr
I tried it with headphones and yeah gtg  :lmao:
So I thought well....instead of looking up the pinout of the critter let's do some probing
First order of the night was connecting a speaker
Then I piped in some signal and started probing away.  I do fully intend to look at the data sheet and schematic that was kindly provided thank you  :dbtu: but I thought it would be cool to maybe try and determine (anything) before having a look.
So I took DC voltage readings on each pin
Then looked for signal on each pin power off probably a dumb idea  :lmao:
Then I looked for signal on each pin power on and whether or not it was affected by the volume control.
Results as follows
Unfortunately I had an overabundance of volume controlled output as in three outa five  :grr
And never did I have the input signal uncontrolled by the volume knob.
But...I just assumed there would be
-input uncontrolled by volume pot
-output controlled by volume pot
So maybe it's time to take a look and see what the expected results are.
 xP
Here in 1994
Volume adjustments usually happen in the preamp.
