Attaching leads/pigtail to molex
Started by saturated, December 11, 2024, 03:14:58 PM
saturated
I have a harness from a boat anchor power supply I don't want to cut it up so I desoldered the male connectors from a circuit board 🛹
Here they are with the harness (the big 🔌 plug top right connects to the PS)
I just need to attach some wire/leads whatever to the male doodads
I think the pins remove and I attach wire or just get pins with wire and install
Thanks   :tu:
Here in 1994
saturated
Looks like I need to get the old pins out which are male on one end and through hole on the other
Then replace with male crimped to wire
Duh   :loco
Here in 1994
saturated
Idk if this is gonna be useful for anything
I'm gonna try the plus and minus 5v on my Op-Amps  xP
It would be cool 😎 to find a good use for it it's built like a tank.  I just don't have an immediate need for 49v DC.
I need to figure out why when I measured across the filter cap I got 78v.   :loco
Also these transformers are kind of a trip it looks like all of the terminals are on one side.
That fan is a beast too.  Crazy how much lint dust bunnies 🐇 🐰 and mud daubers and stuff was inside.
Here in 1994
saturated
I really like TO-3 they are cool I looked them up
The one with the sweet pic 😍 of two diodes is a twin rectifier  :tu:
The 2N3055 is a 60v NPN transistor and apparently is still available.
Here in 1994
Quote from: saturated on December 12, 2024, 06:01:58 PMThe one with the sweet pic 😍 of two diodes is a twin rectifier  :tu:
Interesting.  I've never seen that in a TO-3 package before.  I guess that was before they had the big power bridge rectifiers we use now.
saturated
Thank you sir I roughly eyeballed the male pins and I came up with about 1/16 and that is about 0.063 then I see they have 0.062 and 0.93 (among others I presume)
Then I looked at the extractor tools and stuff and kinda groaned at the startup cost  :grr
Sure would be nice to have those tools though after remembering the times I dealt with them in the past one time repairing a lamp  :grr  :lmao:
Here in 1994
Quote from: saturated on December 12, 2024, 05:48:54 PMIdk if this is gonna be useful for anything
Old guard power supplies, not much use today.
*Guess* +/-5V was for old style Logic boards (where 5V supply was the standard) and +48V is standard for classic *telephone* lines.
The whole bunch might have powered some kind of telephone central, maybe in a small neighborhood or large Factory central.
Analog regulated supplies were very inefficient, hence the need for heatsinking and fan cooling; today any old computer supply can offer 5 Volts at 20-30-40 Amps for peanuts.
QuoteI'm gonna try the plus and minus 5v on my Op-Amps  xP
Way too low for that, they will work but poorly.
QuoteIt would be cool 😎 to find a good use for it it's built like a tank.  I just don't have an immediate need for 49v DC.
+78V is raw unregulated voltage, then down regulated to very clean 48V
perfect for a 100W into 4 ohm power amplifier, single supply of course, like the Acoustic Control Corp Guitar and Bass amplifiers.
You already have the +78V supply, the rest is easy.
Driver and power transistors have modern equivalents, you would need to draw your own PCB.
Power transistors are selected/good quality 2N3055 and you already have them.
You can also use the aluminum sheet heatsinks.
You are 90% there.
You can also build any preamp you like to drive it.
+/- 5V supply can probably give you raw +14/16V if halves put in series.
Not much use for the single +5V one.
saturated
WOW  :tu: a wealth of information  :dbtu:
Thank you so much sir nice to hear from you  <3)
HAPPY HOLIDAYS  :tu:
Here in 1994
saturated
Btw for clarification this is where it came from
My friends wife had an answering service company for years
This satchel/case is ridiculously heavy even with the PS out of it
On the side opposite the PS all these little boards slide in
The boards have some cool stuff like little multi switches
And chips with legs like centipedes
Here in 1994
I had imagined something Phone related, was very close :)
Lots of nice stuff to cannibalize from those boards, at least a lot of good quality relays.
