November 14, 2025, 03:07:10 PM
Fender Deluxe 1996 popping and crackling
Started by Psabin8951, November 21, 2024, 11:41:53 AM
Psabin8951
Hi all I have 1996 Fender Deluxe which is popping and crackling.
Noise is there when all controls are set to minimum so I'm assuming that points to power amp stage. Tubes are not microphonic but is it still likely to be them causing the issue?
All switches and controls have been checked and cleaned and solder joints all appear good.
Any input appreciated.
Paul
Miyagi_83
It might be the tube sockets, the tubes themselves, or filter caps, afaic.
I understand you know how to work on a tube amp, don't you? If not, leave that to a professional.
M.
Sir Francis Bacon
Psabin8951
Resolved. A combination of bad tubes and intermittent switch contacts on extension speaker socket
Quote from: Psabin8951 on December 10, 2024, 11:21:21 AMintermittent switch contacts on extension speaker socket
I guess this was a Hot Rod or Blues deluxe?
