A new book [Op-Amp experiments]
Started by saturated, November 07, 2024, 11:05:16 PM
saturated
Check it  xP
Briefly looking through it it has tons of experiments where he has you make little circuits to make and do cool stuff.
Like....make an op amp differentiator.  And integrator.
Here in 1994
saturated
Good afternoon esteemed members and Mods
I want to begin some experiments in this book
Right off the bat 🦇 I need a 741c
I have a stash of old ic but no 741 c
So looking at digikey there are many different ones (or same ones)
I was able to weed out about half because they are surface mount and I need eight legged DIP
Also there are some Kool TO-99B but they are $17 a piece
The ones that look suitable all have additional prefixes
LM741C-MWC
UA741CPG4
LM741CN
LM741CN/NOPB
UA741CP
maybe I need to compare pinout and data sheets  :grr
Here in 1994
The MWC suffix part is also surface mount.  Any of the others will work.
The letters in the prefix designate the brand of manufacturer.
saturated
Thank you sir
I just enjoyed reading about Burr-Brown I had actually never heard of them until now.
Btw happy holidays to all of you  :dbtu:
Here in 1994
saturated
#4
I have a few items in cart at digikey I'm gonna finish my list tonight and get this stuff on the way.
This is some good stuff because I already have a problem  :tu:
So I'm looking at this diagram and getting stoked about doing it  :dbtu: but then I'm like oh no...
How do I get a minus fifteen volts on the device  :grr  xP
So I had what I thought was a major epiphany and said ah ok just hook the neg of the power supply but make sure the neg is ungrounded
Being proud of myself 💪 I said yeah I can test this and made the following circuit on breadboard.  And it didnt work (fortunately)
:loco
Since it didnt work I figured ok maybe my negative is connected to ground so I checked for continuity and resistance and they are not connected.
To add to the confusion  :loco as I type this I anticipate that perhaps the Op-Amp will show -15v because for lack of better words (maybe ?) it's not resistive.  Sorry for opening a can of worms.
But at least I'm getting out of the "dude...neg is ground" mindset.  Because sometimes it is.
I'm kinda glad I get to order a green 💚 jumper cord.
Here in 1994
For your positive supply you have the neg. lug connected to ground, yes?
For the negative side you connect the positive lug to ground.
#6
If you have two 9V batteries and you want 18V you connect the plus of on battery to the minus of the other battery, result is 18 Volts.
Where the 2 batteries meet is what we normally call ground, and then you have plus 9 volts and minus 9 volts on either end compared to the ground.
From the minus 9V to the plus 9V will be 18V
On some schematics they just say 0V, 9V, 18V instead of -9v, ground, +9V.
There are so many variations but after some time you just know what they are with a quick glance.
I find having a positive and a negative supply with a ground much easier to trace and understand  a circuit because sine waves have positive and negative sweeps, just think of that oscilloscope waveform where the middle is 0V or ground.
I just had another look at that power supply you have, there are 2 switches on it.
IND would mean the 2 outputs are separated from each other, not connected to each other at all.
SER would mean in series, I presume that this links the 2 outputs so you have a +,0V, - output.
SER will give you  double the voltage of one output but no more amps.
PAR would mean parallel and the two outputs will be joined up with + to + and - to -, you get double the amps compared to one channel but also only the volts of one channel
Try it with the switches set to SER and then measure the voltages of the 2 outputs, I imagine the plus on one side is equal to the minus of the other side.( they will be linked by the switches internally)
saturated
#8
Thanks guys  :dbtu:
I have to go through my stuff and see which of these resistors and capacitaters  xP I have and don't have
Shouldn't take more than a couple of weeks  :loco
Here in 1994
saturated
A major technological advance has been made.  :lmao:  Negative voltage has been achieved  :dbtu:
Thanks to G1 and Mick  :tu:
So per instructions the (+) is connected to to ground on different power supply.
Pretty cool I confess I was fearful of some 🎆🎇 fireworks
I guess the important part is the negative of the power supply must not be grounded.  Then it would be the fourth of July  xP
So that's cool I have my chips and stuff on the way and it seems to be a common theme with these guys to connect V+ and V-
But then other ones had stuff like Vc and Vd but I'll worry about that when I get to it.
Here in 1994
