Tone burst generator
Started by saturated, October 13, 2024, 07:31:47 AM
saturated
Another new toy yay
It's guaranteed to work because there was a sticker on it that said "checks ok date 1968"
I didn't have much luck with it it did power on I ran a sin wave thru it to my scope and when I turned knobs and flipped switches all it did was flip back and forth from a flat line to a sin wave.  Turning the knobs affected the rate.
Then I ran it into an amp and just got Morse code.  :loco
Help is otw though....I couldn't find a manual for this exact manufacturer model but did find a manual for a similar model gen rad.
Also I ordered some BNC to BNC cables to make life a little easier.   :grr
There is not much info I could find out there about these devices apparently they were used to test stuff that now they do the same testing with stuff that made these boat anchors...idk.  xP
I just want to get some cool looking stuff on my scope.   8|
Here in 1994
"all it did was flip back and forth from a flat line to a sin wave"
Flat line is no signal, sine wave is burst, so it's doing it's job.
It could make bursts of whatever kind of signal you run in to it, square wave, pink noise, etc.
saturated
Yes sir thanks
Probably beyond the scope of this conversation (on my end) but I was hoping for like a brontosaurus type burst
and I don't recall it ever being anything besides a uniform amplitude from beginning to end.
https://youtu.be/cAYDiPizDIs?feature=shared
Here in 1994
That would be amplitude modulation in addition to the burst.  I don't see anything like that in the controls.
saturated
I got home from work and played with it some more since I got some Kool BNC to bnc cables.
Btw here is how I know it's good to go
Anyhow man I twiddled knobs and controls for a while determined to get a trigger where it wasn't moving but failed  :grr
So I snapped a few pics hoping to capture something
The rectangle burst things are cycling left to right
At an accelerated pace  :loco
Here in 1994
Adjust the timebase control on the scope to widen out the burst.
