Adding a balanced XLR OUTPUT to a SS Amp
Started by aoresteen, August 18, 2024, 10:30:06 PM
aoresteen
My Fender Frontman 25R project continues.  I need to add a microphone level XLR balanced output to feed it to to the PA mixer board in it's own channel.  My Carvin SS bass amp has such an output that I use all the time.
The signal level from the pre-amp to the power amp I assume is line-level which is too hot to use.  I could use a DI box but I would prefer to just have an XLR socket on the back of the amp and avoid using a microphone. Use would be primarily for live gigs.
Ideas?
TIA!
Tony Oresteen
Peavey Bandit Silver Strip, Revolution 112
Marshall MOSFET Lead 100 3210
Fender Frontman 25R 2010ish
Newnan, GA
A typical circuit will include a low pass filter to simulate the response of a guitar speaker. If you search here, you can find several.
Yes.
For the full experience, take speaker out signal, which will be about 10V RMS (WAY too high) and attenuate it 100:1 to 100mV using a 2 resistor voltage divider: 100k in series, and 1k to ground, which is perfect to feed it into a mixer Line input (every channel has one), no need to super attenuate it to microphone level (a few mV), nobody does that.
Insert a direct box circuit in the path as suggested earlier.
For example: Hughes and Kettner famous Red Box
Schematic and suggested PCB is widely available.
