November 30, 2025, 08:18:08 PM
Hotone Ampero Mini - The mini modeler for you?
Started by joecool85, June 28, 2023, 08:52:01 PM
Hotone, known in these parts for their nano amp series mini heads, has released the Ampero Mini.  This is a small pedal-sized modeling amplifier with a touch screen interface and two stomp switches.  Using two 24 bit DSP chips, this little guy can utilize as many as 9 effects simultaneously.  It comes with 199 effects, 52 amps and 50 cabinets available. You can also change microphone type and position simulation.  Lastly, it includes 100 drum loops to use as backing, and has a built in stereo looper effect allowing for as much as 100 seconds of mono or 50 seconds of stereo loop!
These new little modeling platforms will be coming in 6 colors and selling for around $290 USD.  If you're into modeling amps and don't have the money for some of the fancy ones - this may be your next jam!
https://www.gearnews.com/hotone-ampero-mini-smaller-cheaper-and-powerful/
