December 01, 2025, 01:18:17 PM
my oscilloscope
Started by saturated, April 15, 2023, 12:41:15 PM
saturated
did not power on
found an open fuse
replaced fuse
put on dbt looked good
powered on but has no trace
crt is glowing a little but not much
the slide switches are extremely stubborn
you practically need a hammer and chisel to move them
I am aware there are crazy high voltages in these things so I havent fooled with it  :)
I ask stupid questions
and make stupid mistakes
criticism, critique, derision, flaming, verbal abuse welcome
With the Sweep in NORMAL mode, there won't be a sweep unless you get a trigger somehow.
With EXT trigger source, you won't get a sweep unless you connect a signal to the External Trigger Input and adjust the trigger level control to get a trigger.
A drop or two of contact cleaner in each of those switches will free them up. Don't touch the end of the CRT tube shown in the picture.
saturated
hello everybody i think i want to try to get a trace on this device by (with your assistance) checking the power supply
obviously i (we) want to steer clear of high voltage areas
the same pics of the schematic are all over the net
thanks for your help meanwhile i am going to look for some (low) voltages to check
Do you have any wall warts with AC output ?
A nice small 9v AC would be a good test to do.
The older heavy DC ones usually have a transformer in them, you could test the DC voltage on AC and look for a ripple.
saturated
thank you sir that is an excellent suggestion
today I decided to look at this thing...todays goal was to be able to find something on the device then locate it on the schematic...or vice versa.
I was able to locate the two (bridge rectifiers)? and then test the voltage at point T (white wire) and I got 193v. (supposed to be 185v so I guess that is good)
one thing i noticed was the two rectangular resistors next to the diodes were pretty warm maybe that is normal but ones elsewhere were room temp.
there is a voltage between d408 and d410 supposed to be 19v but i cant find a place to put my probe to test.
Those wirewound resistors are 5 watt and 10 watt for a reason, so they will get hot.
