October 20, 2025, 09:42:02 AM
Fender Stage 112 SE - Transformer wiring
Started by SpiralBlue, March 08, 2021, 06:28:44 PM
SpiralBlue
Hi all.  I was hoping to find someone with a Fender stage 112 SE that could show me a picture of the wiring points of the transformer (a picture is worth 1000 words, right?).  I had a friend bring me this amp hoping I could wire it back together.
I've been over the schematics but not really finding a related point to work with on the PC board.
Thanks in advance.
#1
Where are you located ?
Are you wiring it for Domestic (110Vsc) or Export (220Vac)?
Here is the 'Domestic' layout.
Blk (CP8)and Wht (PS4) are the Primary leads from the Mains plug.
I can only surmise that the Wht wire (PS4) indicates Power Switch tab 4.
Red -Ylw- Red:  is the 45 Vac taps with Ylw being the Center Tap
CP1-CP2-CP3
Blu- Brwn- Blu is the low voltage Vac tap with Brwn being the Center Tap.
CP4-CP5-CP6
The tabs on the PCB should be clearly marked.
