November 07, 2025, 11:57:36 PM
Transistors for Unicord Stage 65b Amp
Started by Sfmag1, May 26, 2019, 05:50:24 AM
Sfmag1
Hello. I'm trying to locate and purchase these TO-92 case audio transistors in a 1977 japanese made amp but even a google search does not recognize the numbers. Any help or suggestions? Thanks
C693F7F
A640E76
C1175E7F
C536G7C
A659E6G
Try searching this;
2sC693    F7F
2sA640     E76
2sC1175    E7F
2sC536     G7C
2sA659     E6G
google search with "2sc693" brings up this;
https://alltransistors.com/transistor.php?transistor=16964
It's common ,,they don't print the whole part on the device.
Leave off the the end 3,, they will turn up in a search.
Be aware that a lot of other Equivalent transistors will likely work.
The main thing is to find a device with similar specs.
Main things to note are;
Maximum Collector-Base Voltage |Vcb|: 40 V
and
Maximum Collector Current |Ic max|: 0.05 A
and
Maximum Collector Power Dissipation (Pc): 0.1 W
Alltransistor has a Cross Reference Search.  :tu:
HTH,, phil.
