November 07, 2025, 12:27:12 PM
Unicord Stage 65b Output Transistors
Started by Sfmag1, April 29, 2019, 02:00:22 AM
Sfmag1
Hello. I have been working on a Unicord "Stage" 65b amplifier and ordered and installed replacement output transistors Sanyo B507E and D313E. They work alright with a signal from a generator or guitar at very low volume but  heat up and will burn/short out completely if left on with a louder volume setting. The sound is good out of an 8 ohm speaker until it is turned up, then they heat up. They would be normally mounted to the chassis to dissipate heat but they are burning hot anyway. The speaker reads ok at 8 ohms. I am suspecting the Chinese transistors I bought from e-bay are cheap junk and that is the problem. Any experience or advice on this? Should I buy an equivalent?
Tx
Quote from: Sfmag1 on April 29, 2019, 02:00:22 AM
Tx
ARRRRH,,  :o  Stop!!!  :o They have to be mounted BEFORE you turn on anything.
That is why the heat sink is there,, they cannot work without a heat sink.
Agree^^^
ALWAYS put the power transistors on the heatsink before powering up.
How long would you run your car engine with zero water in it?  Or with zero oil in it?
Sfmag1
#3
Ok noted and will try. ???
Sfmag1
Ok mounted to chassis and so far so good. :dbtu:
