Simple SS Power Amp Build - +/- 40V Push/Pull
Started by ilyaa, December 04, 2018, 03:25:24 PM
ilyaa
hey guys!
been a minute -
trying to clean out the crap pile while things are a bit slow at work -
i have this Polytone amp thats been taken apart for quite a bit now - the preamp is perfectly fine but somebody tried to "repair" the power amp and its just a total disaster.
the PT is fine and I decided I am just going to gut it and build a simple power amp from scratch so I can get this thing back to life -
I've got +/- 40V and heatsinks for two output transistors -
Also have a second, lower voltage tap (about +/- 20V) -
can you guys recommend a simple power amp build I can retrofit to this thing? its got a nice cab and a nice preamp with reverb and tremolo and everything - shame for it to die on this bench!
There are a bevy of class d amps available on the net.
Small & simple.
Pick one that utilizes the +40/ -40 Vdc supply that you have.
