November 13, 2025, 10:17:21 AM
Roland CUBE 100
Started by tette2, March 14, 2017, 11:21:36 AM
tette2
Hallo !   This is my first post here .   I have changed all  electr. caps in this guitarcombo .  The amp works fine with a very nice sound if I start it
without a speaker connected .  And then connect the speaker .   But if I have the speaker connected , like it should be normally ,  the amp
tilts and the protection lamp I have in series from the walloutlet  ( 230 VAC )  glows ....  current flows ..... probably through one of the powertransistors while the other is choked..... ?    Thanks for some advice ...   tette
Your protection lamp is causing the problem.
If you do not measure DC voltage on the output with speaker disconnected, then you do not need the protection lamp.
