Princeton Chorus SS Board Advice Needed
Started by MurphyPeoples, January 07, 2017, 08:18:43 AM
gbono
I think your initial question was a touchy volume control on the amp. If you look at the schematic for this amp the volume control pots are "B" taper - i.e. linear slope. Unfortunately, we hear increasing sound amplitude in a non-linear fashion. Not sure if this was a marketing ploy by Fender since I always here people complain about the SS amps from the 80's and 90's being too loud and they can't be turned down. Changing to an "audio" taper/slope will help this issue.
MurphyPeoples
Quote from: gbono on January 12, 2017, 07:52:43 PM
If anyone has done this and knows of the part number, I'd be grateful for the info.
galaxiex
Not sure but it might help....
The link I posted in post #3 has articles for fixing the HRDX volume problem, same problem, use of a linear pot instead of log.
Here's the link again...
http://hotroddiy.com/howtoarticles.php
Read the article "Controlling the Hot Rod's Volume" go to "Master Volume Mod" within that article.
also see..... "James E Vanden Berg Mods, The"
Just rereading the first post I think the issue might be *Volume jump* likely due to a cracked pot track or cold solder join on the pot mounting, either way a new pot will fix that.
MurphyPeoples
Quote from: galaxiex on January 13, 2017, 08:24:22 PM
Bless you for that info! Brilliant.
donnie
I had one of those amps a while back. If I recall correctly, I changed the volume pots to logarithmic to get better volume control.
Sent from my SM-N910V using Tapatalk
MurphyPeoples
Thought I'd give a final update. I changed out the jack with the "low cost" model to which I provided a link early. At half the price, they came in looking great, and once installed worked PERFECTLY.
I D5'd out all pots, and reflowed the soldier to each one plus the Caps. When I cut the amp back on, it sounded GREAT. No volume issues, and just had that warm Fender tone. Really surprised at how great
the SS Princeton Chorus sounds!
Next Up : Late 1980's SS Pro 185. Same issues.
Glad I bought many extra parts!
Murphy
