April 27, 2024, 06:05:22 AM
Baldwin C2 amplifier output section
Started by groovtubin, June 23, 2015, 03:37:29 PM
groovtubin
Need to replace the output transistors ( 5 ) in a Baldwin C2 guitar amp, ( leakage on edge on ALL.., low gain on 2 ofem) the PN is 466 then TRPV  6849
ANyone have  across reference?
Thanks in advance!
jim
Are they actually dead or something?
I guess they are Germanium and in that case leakage is *normal* .
What are you exactly trying to fix?
groovtubin
Quote from: J M Fahey on June 26, 2015, 12:43:43 AM
Found the REAL problem, ( after repairing power supply) Q12 is MISSING in the splitter of driver section, Looking at the reverb section ( same part #`s) Q12 is 2SC253383...would you have a cross reference on this? Man, i`d really appreciate it!
respectfully, jim@Omegaamps.com
Hi Groov, welcome to the place.  It is good form to at least link a schematic when discussing something, especially an uncommon amp like this one.  I Have no idea where Q12 might be.
Just looking at your part number, I have to assume the part is a 2SC2533.  The 83 is probably part of a date code or something.  But I could be wrong.
LateDev
Have to agree with Enzo,
Here are the stats on the 2533, the page has an equivalent search on it
http://alltransistors.com/transistor.php?transistor=13340
groovtubin
#5
Quote from: LateDev on June 30, 2015, 11:01:20 AM
THANK YOU GUYS  A MILLION! Do you know the PNP sister PART NUMBER to the 2SC2533? Thanks in advance!
jim
Quoteat least link a schematic when discussing something, especially an uncommon amp like this one.
[2]
Without a schematic, I haven't any idea what to tell you.  You apparently have the schematic, so can you post or link it?
