November 01, 2025, 10:42:39 PM
hiwat maxwatt g100r problem
Started by aly68, January 17, 2014, 09:53:50 AM
aly68
Hi everyone !
I have found a simmilar topic but not replays for a long time so I decided to start a new one.
Yesterday I have recieved used Hiwat Maxwatt G100R and when I plug the guitar signal was waaaaay too weak and amp is producing a kinda farting sound. I have mess a little bit with controls, switches and everything and channels were switching, gains were switching (for tone controls is a little hard to say from obvious reasons)...I checked cable, input, guitar (replace guitar and cable) and nothing changed. Then, all of a sudden it came alive and everything seems to function perfectly. Then I played guitar for a while (15-20 min) and - BAM- how it came, it goes same way, started to fart and cut output signal to 5% (not dead completely). Then I try to hit it from up above (Russian principle  :tu:) and then it start to come and go, than it went for good. I had to go somewhere but when I come back after few hours I plugged it in again and-it worked perfectly. Than I become pissed off and, while guitar was plugged in and on the drive channel, with one hand plucking the guitar and with another hand I grabbed it for handle and rock it back and forth for some time, trying to provoke upper mentioned situation. And after 10-15 rocks it went off the same way.
Afetr that, I have try to rock and pull wires from speaker but nothing have happened. I have plug out the guitar and amp from outlet and roll amp on the front side and look at speaker again, checked wires but everyrhing seemd to be ok.
Today, I contacted previous owner but he swears that the amp was in perfect order.
Is it possible that something gone wrong in transport ?
Please, if there is anybody that experienced the same with this amp, or somebody that think that he knows what's going on, give me replay !
Thanks in advance !
Connect the send to the return jacks with a cable.  Does the problem still happen?
Hi aly68, welcome.
Quote from: aly68Is it possible that something gone wrong in transport ?
In this case, yes.
Quote from: g1Connect the send to the return jacks with a cable.  Does the problem still happen?
:tu:
If this fixes it then it's just dirty contacts in the Fx Send and/or Fx Return sockets - very common fault.  Give them a shot of contact cleaner or metho/alcohol and work a plug in and out several times.
aly68
Thanks for your input, guys !
Anyway, just power up the amp and , of ourse, farts. Again, I tried to rock speaker wires and so on and nothing happened. Than used one cable to connect loop and problem remains. BUT !
When I was disconnecting loop cable, when I pull out send jack than , amp come in alive ?
And, now still is. Can it be the problem ?
BTW, I tried to seek help from our amp gurues but fixing a solid state is...mmm...I don't know your phrase...but they think that SS amps are garbage and not worth their time
An amp is an amp is an amp...
Quote from: aly68when I pull out send jack than , amp come in alive
Dirty contacts.  Or perhaps a broken solder joint on the connector, either way you're poking the fault.  :tu:
aly68
Thnx, Roly !
Tried to connect and disconnect jacks of the loop several times while amp still working and, from then, everything still works !
I even powered off the amp and just before few minutes powered it on and plugged guitar and -IT'S STILL ALIVE !
I hope that it'll remain that way. Maybe nothing is broken after all !
We'll see. If the problem persists or return I'll be back !
Thank you for everything once more !
  The odd thing is that you still had the problem when you had the cable connecting send to return.  That should have bypassed any problems related to the jacks.
  Was the problem definitely still happening when you had the cord from send to return?
Dirt is dirt, sometimes it takes a moment for a clod of it to fall aside.
Grab all those "amp gurus" who told you SS amps are not worth fixing and drop them here:
Quote from: g1 on January 17, 2014, 04:40:17 PM
The socket switch contacts tend to go open due to corrosion/oxidsation build up due to lack of use, but the same effect occurs to the actual socket-to-plug leaves 'tho working a plug in and out a few times generally cleans them by direct abrasion.  Good shot of vodka up the 'ole and working a plug in and out a dozen times generally does the trick for both sets of contacts.
aly68
Thank you, guys for your help !
Amp now works with no problems !
When I briged send and return loop inputs with cable, problem egzisted only to the point I have removed jack from send input and then amp come alive. From then, I plugged in and unplugged jacks to both inputs several times and amp works as it should.
That hole in the ground is scary, however, your idea is still tempting...
I realy like this : "An amp is an amp is an amp..."  :tu:
This is my point of view regards guitars : I like to tune them in every possible way, just to make them best they can be, cheap or expensive. All of them are instruments that can make happy someone trying to make music ! :dbtu:
So, once more, thank you !
QuoteWhen I briged send and return loop inputs with cable, problem egzisted only to the point I have removed jack from send input and then amp come alive. From then, I plugged in and unplugged jacks to both inputs several times and amp works as it should.
The issue most likely seems to be of intermittent nature.
Corroded or dirty FX loop contacts are a common problem in that regard and most often easily cured by plugging in and out a coord few times, which scrapes of most of the corrosion and dirt from the contacts.
On the other hand, if the issue is a faulty solder joint it can portray the very same symptons and can be sometimes even cured by the same FX loop method as stress applied to the jacks and even the whole PC board might momentarily revive the intermittent contact. Needless to say, if that was the issue the fault symptoms will usually return after a while and Mr. Murphy ensures it happens right when it's not supposed to.
Quote from: teemuk on January 20, 2014, 09:54:03 AM
I carry tobacco pipe cleaners, available where tobac is sold.
I get ones with a stiff plastic twill in the cotton fluf.
hairpin-fold at 1/3rd length
dip in dry metho
scrub inside socket
can get two cleans out of one cleaner
Spent ones can be used to give plug stems and tips a wipe before they dry out.
... or you can do other things with them ...
aly68
Great tips for cleaning, guys !
But, here we go again !
Yasterday I took the amp to my friends house for jamming and rehearsal. He's living a 100 m from me and I've transported the amp with a two wheel troley (or whatever you called it)...no too much bumps or anything...
And when I power up the amp, first there is no sound at all, completely sound dead. I thought that there some guitar cable has problem but when I changed it nothing has happened. Then, all of a sudden, it comes back. BUT...
I've played 20-30 seconds and previous sindrom comes back : farting or no sound at all. I have briged loop with guitar cable expecting a solution but nothing's happen. Then I realized that, when I slightly pulling out the main input jack from socket something crackle and the amp come alive. After that, I've put some contact spray on jack of the cable and put in-pull out input socket 20-30 times. And the amp start working...for maybe a minute than stops again. Than I went REALY pissed of and plug in another amp to finish the rehearsal.
Now, i found ineresting the fact that I have tried to rock input socket while the jack were still in it back and forth, left right and up and down and nothing cracled, nothing happened at all. I thought that it will crack or anything if the socket maybe have faulty soldier contact, but nothing.
In the end my fellow bass player said that I should try to power amp once again (despite all, they really liked how the amp sounds when it's working)) and I did and it works about a minute and then died again.
Now I'm really furious because I know a previous owner and believe him when he said that the amp worked with no issues, but now I don't know what to do. I know to fix guitars but don't how to fix an amps and don't have qualified repairman for the task ( from aforementioned reason). To complete irony, I had offers to sell the amp before this happened and, of course, they are withdrowned. Damn !
Quote from: aly68 on January 21, 2014, 03:36:03 AM
Arrh,,Sounds like the input socket needs attention.
Might just be a cracked or cold solder where the socket mounts on the PCB.
Also could be the tiny terminals inside the socket have died, if it is the fully encapsulated type.
In that case you would need to replace the socket.
