October 23, 2025, 06:35:45 AM
Fender "Blues de luxe" and AX1000G
Started by ksor, March 29, 2013, 02:08:55 PM
ksor
How should I connect this guitar processor RomeWorks AX1000G to the Fender amp - if I just put it "in front" there is a lot of noise - if I use the "effect link" on the back of the Fender there is a LOT OF FEEDBACK howling !  :duh :duh :duh
how should it be done ?
Welcome Ksor,
Not familiar with the unit but I'd guess You Turn down the master level on the AX whatever.
Trick is to find a Level balance between efx unit and Amp input.
ksor
>> Phil
Just turn the master Downon the AX1000G and then through
1) the normal INPUT
OR
2) the effect-loop on behind the Fender
what is "best practice" ?
It's a matter of what gear you have and as there are just so many way to skin the beast you have to suck it and see.
A lot of efx loops are not all that smart (IM observation) and maywell be more trouble than they are worth.
Your Amp likely has the 2 inputs , one high and one low,, try using the low input it may work better if the input signal is very hot,, less hiss.
Cheers, Phil.
Agree and add: I *think* the processor expects to get a guitar straight at its input and drive directly a power amp (which are quite insensitive) .... and you are hitting with all your Fender Preamp gain and driving the EFX IN which still has some gain added before actually reaching the power amp proper ... so you have a lot of extra, unexpected gain.
Same what Phatt said, only in more words.
Google and post here the User Manual, so we can suggest something more accurate, but the general idea still is to tame that extra gain.
Welcome Ksor.
Looking at the circuit of the Fender Blues Deluxe the Power Amp In appears to be quite sensitive, only about 35mV for full output, in fact this should be similar to the normal main inputs.
If you don't have a users manual for the Korg AX1000G then you can download it from www.korg.co.uk/downloads/ax1000g/AX1000G_OM.pdf.  If you haven't, I suggest you download and read.
You could make up a simple 10:1 or 100:1 output attenuator lead with a couple of resistors in one of the plugs, but have you tried setting the Master Level to a low value?
ksor
Quote from: Roly on March 31, 2013, 03:56:15 AM
Welcome Ksor.
Thx to all of you !
I think I'll try the "lowering-master-method" in the first place  :)
