November 06, 2025, 09:17:04 PM
ss amp, no distortion... add a 2nd volume to get gain?
Started by darren, August 09, 2012, 07:35:19 AM
bobhill
And BTW, I also made a bass version of this pedal that has grind down to the low B on a five string that I will post on the Preamp section
bobhill
Bass pedal (Lowered Expectations) posted in the schematic section.
Quote from: bobhill on August 10, 2012, 12:20:22 PM
Oops, put the wrong layout with it. The one posted was my first attempt to add a bax style tone stack to it (that failed), so ignore. Here is the correct layout. Mods, could you delete the layout from the previous post? Pretty please :tu:
Which filename is it you want gone?
bobhill
tubebass
One of my pals built a TA-16 around 1974. He wanted more treble, so he put .001uf capacitors across all resistors in series with the signal path. Worked ok.
darren
and how does one do such a thing?lso like to build a new cabinet for it. both will happen, but first id like to try the caps.
Quote from: darren on August 14, 2012, 02:42:05 PM
Sounds like he literally soldered one leg of the cap to one left of the resistor then the remaining leg of the cap to the remaining leg of the resistor.  This could be done on the top or bottom of the PCB depending on how much leg is visible on the resistor.
darren
any ideas as to how this would sound? seems like an easy fix.
