HELP choosing an AMP!
Started by daozen, May 11, 2012, 03:07:26 PM
daozen
Well, I'm finally getting a band together after about 14 years of playing and making music :D but I know little about live sound.
I've got a cheap Johnson guitar/amp combo I got more than 12 years ago, and I've never really played anything else. I do use a korg effects pedal to get a decent sound, but I can't play the guitar clean as it sounds like the cheap chinese thing that it probably is, but I actually love how the 30 watt amp sounds!!! I set the knobs on full vol, full overdrive, and on top of that, it gets the full tube overdrive effect and a decent amount of delay and reverb from the pedal. It always sounds like it's screaming for it's life at very low vols, but I'm not sure about how much of the sound comes from the pedal and how much from the amp.
I'm getting a deluxe mexican Fender strat soon (vintage noiseless pickups), and I'm thinking about getting the Frontman 212r amp to go with it but I'm not sure about it!!! I feel I won't get the singing overdrive I get from my cheap 30 watt amp. At the same time, I'm not sure if I will be able to mic the amp at every gig, as I own neither an extra mic nor a proper PA so I would have to rely on the local setup everytime, can that be a problem? Or is it rare they won't be able to mic the amp?
On the other hand, I feel the f212r is perfect in terms of price and usability. I wouldn't have to rely on miking the amp for starters, and it seems I won't need a bigger amp unless we start playing stadiums. I play using mostly overdive and delay/reverb but I would love to use clean stuff aswell as my complex chords lose color and get muffled with the overdrive. So, will I still be able to get the crazy overdriven sound I get from the pedal alone if I get the 212, or if not will it still sound better on both the clean and overdriven setup with the help of the pedal?
Thanks Anyone!
mexicanyella
#1
Those are hard questions to answer without knowing more about the people you'll be playing with, and to a lesser degree, the venues you'll be playing in.
I've heard people say that you need a 50-watt half stack to comfortably play with drums. But drums, drummers and drumming approaches vary A TON. The volume sensitivity of your bandmates matters A TON. My first band had members who were pretty volume insensitive, and made up for it by having really big amps and a loud drummer. It was a thrill some of the time and a mixing headache (and general headache) other times. I'd have hated to have been our soundman.
My two subsequent bands existed with much quieter stage volumes, more reserved drumming, a smaller bass amp and I was able to get away with a pair of 15-watt tube amps fed by a couple of pedals and a stereo reverb unit. The amps were up maybe halfway and it was plenty loud. I got by at practice with the same pedals into a 12-watt solid state Peavey, and had to gig with it once in awhile (paired with a borrowed Crate GX15) when the tube amps were malfunctioning.
So if you're not in the full-on "REJOICE, ROCK BONEHEADS!!!!" mode,  you may be well able to get by cranking on your little Johnson (sorry). Your point about wanting to get more into using clean sounds...well, that may be an issue with that amp size. When I was using those little amps, I generally hovered right at the edge of distortion on most of my playing and never did anything that was crystal clean. I'd have needed more watts if my approach had incorporated that kind of stuff.
We played a variety of different-sized and different-budgeted clubs around St. Louis, and a few outdoor things or college auditorium-type things, so I think we experienced a variety of different stage approaches, and generally, if you're playing little neighborhood dive bars, the PA--if any--will likely limit you, by its small number of channels and limited monitoring, to running band vocals and maybe the kick drum through the PA. But you might still get by with a 30 watt amp, cranked and dirty, unmiked...if the drummer and bass player are hip to controlling their volume.
Larger clubs should have enough PA input channels, mics, stands, cables, stage snake channels and whatnot that it would be reasonable to expect all amps to be miked or DI'ed, plus multiple drum mics and vocals for everyone who sings. With everything miked, it's down to whether you can make enough stage volume for everyone. Careful positioning of your amp to tilt back, or raising it up on something, or aiming it across the stage, can get it so all members can hear it without cluttering up the monitor mix with guitar signal.
In short, try it. You'll know pretty quick if it's working for everyone or not. If it's the only sound/tone you've ever gotten used to, TRY EVERYTHING YOU CAN if decide to upgrade. There are many options and many possible things that will seduce you in the store but not seem so cool once you get them home. Always tell yourself this when you're gear-testing:
"If I have to ask myself if I like it, I probably don't like it. If I don't know that I like it within the first minute or two of playing through it, there's a good chance that I don't, or won't, like it."
Some gear takes some time and effort to tweak and get it to work but shouldn't be written off because of that. Like, say, a lot of Mesa amps. I have yet to bond with any Mesa amp, but a lot of people like them and they seem pretty sturdy...anyway, try everything you can get your hands on if you decide to upgrade. If you don't decide to upgrade, have fun with your exisiting rig and make every attempt to work in the phrase "my little Johnson" in conversations.
mexicanyella
Just in case my post above didn't seem long enough, I'm posting a second time, with even more words!
Quote from: daozen on May 11, 2012, 03:07:26 PM
I've gone through various gear phases but for years now have been using my first amp my parents bought me way back in high school...the little Peavey Audition I mentioned before. After "outgrowing" it and passing it on to various little cousins and nephews to learn on, it came back to me several years later and I realized I really liked how it sounded. I just needed to spend some time convincing myself I was a real guitarist because I had a big amp, first. If you like the tone you're getting now, maybe you can skip that wasteful "I'm legit because my amp is big" growth phase...?
You don't mention what kind of guitar/pickups you're using, or what kind of music you're playing, but if you've got a compressor in the Korg, and especially if your guitar has single-coil pickups, gentle compression can really help little solid-state amps get a more pleasing clean tone. Set correctly, the compressor can soften note attacks a little, or add punch, or sustain, or some combination of all of those, and also help make a nice cutting rhythm tone that's right on the edge of distortion. You want to use lower gain settings earlier in the amp's signal path (on my Peavey, that is called "pre gain") and crank the later gain stages to make up the volume (post gain), so you're pushing a louder, cleaner signal through the power amp and working the speaker harder. In my case, running all three EQ knobs at low-to-middle settings helps the tone seem fuller, rounder and less harsh, but still plenty bright, and with lots of adjustability range up or down. Trying to pull a bunch of bass "chunk" or get a big scooped-mid sound out of a little SS combo is kind of spinning your wheels. But you can punch a bunch of snarly, midrangey rock craziness through a mix with a small SS rig. Here's a recording of me doing that with a single-coil Gibson Melody Maker, a DOD clean boost pedal for solos, a DOD compressor pedal and a Peavey Audition 20. All the electric guitar you hear is that setup:
http://alonetone.com/benniven/tracks/bleach-bald-snow-tires
Even if you don't like that kind of tone as much as me, you can hear how it's pretty present in the mix. That's not because I'm a great audio engineer; it's because the amp is putting out a nice cutting sound and not competing with the other instruments for mix space. Keeping that kind of thing in mind will help you in both live situations and recording.
I've heard that Jonny Greenwood from Radiohead gets his dirty sound from a SS red-knob Fender combo (an Eighty-Five, maybe) with everything pretty much dimed.
Spend some time just plugged straight into the amp with no pedal and give it a workout; you'll figure out how much of it the amp can do eventually.
You have no way of knowing the answers to those things until you have the new guitar and can try it through some stuff. Don't rush it. See how it works with what you have, and whether you like it or not, go put some music store showroom staff to work and try stuff.
Re: the PA, talk to some bands that play places you'd like to play, and get a sense of what places around you hire bands that play your kind of music. Find out what range of sound systems they have, or if you need to be packing your own.
If you need to pack your own and will be playing small places, check CL for powered mixer heads from Peavey or Crate; there are usually 4- and 6-channel ones available pretty cheap. You can amplify a couple vocalists, the kick drum and maybe the snare through a pair of small PA speakers on speaker stands and play smaller bars and parties and stuff like that. It'll sound good enough to have fun doing it. Add a small powered monitor, or a non-powered monitor or two with a power amp fed from one of the PA head's auxiliary outputs, and you'll even be able to hear what you're doing on stage...a total luxury.
On the other hand, I feel the f212r is perfect in terms of price and usability. I wouldn't have to rely on miking the amp for starters, and it seems I won't need a bigger amp unless we start playing stadiums. I play using mostly overdive and delay/reverb but I would love to use clean stuff aswell as my complex chords lose color and get muffled with the overdrive. So, will I still be able to get the crazy overdriven sound I get from the pedal alone if I get the 212, or if not will it still sound better on both the clean and overdriven setup with the help of the pedal?You can't answer that yet. Too many unaddressed variables. You seem to like the amp you have, and miking...it's not a big deal. You WANT to find places with good enough PAs that you'll be miked, regardless of how big your amp is. The question I think you should be concerned with is whether you can hear your amp over the other bandmembers, and whether they can hear you. If so, move your show onto a stage and mic stuff and then you'll be good. You can't assume you'll need a bigger, louder amp so you can be really big and loud. You need to think in terms of the ensemble you're in and how big you need to go to hold your own there without blowing your bandmates off the stage or making them strain to hear you.
Thanks Anyone!
Hello daozen,
Take your much loved Amp to the shop and side by side test it out against the big brand robbers Amplifier names.
An,,Tell the shop owner to shut for at least 10 min.
*Note* Small Amps will always come out sweeter sounding than big Amps.
If you need more power from a small Amp??? Just 2 resistors from the speaker (maybe add a pot for some control) and send the signal to a second amp for more room fill.
If I had a dollar for every guitar player that purchases a bigger amp rather than linking two small amps ,,, I'd be stinking rich. :lmao:
9 times out of ten,, Bigger Amps will just get you frustrated.
If the gig is really big Hire professional people to setup the rig. :tu:
mexicanyella
Yeah, I'm with Phatt on that one; running two little amps has always worked well for me, either as a stereo pair or in a master amp/slave amp situation.
Can you post the model of amp you're using, or some photos of it, or something? Seeing its specs and features might prompt ideas for you to try with it, etc...
daozen
Quote from: mexicanyella on May 12, 2012, 12:00:06 AM
hahaha! best joke ever! ahaha, Well, thanks man! very good and thoughtful advice there. My logic is that if I'm getting a strat, a Fender amp will be able to highlight the sound of the guitar the best. I now think 100 watt is overkill given most reviews say people never set their frontman 212r over 2 1/2 vol. I don't feel like looking at other brands but there doesn't seem to be a 1x12 fender size solid state amp worth having, or is there?
I guess the store is where one really knows about all this but I like to go there well informed about what my options, once in there, will be.
If I find nothing I'm sure my little Johnson will still make the girls come to my shows...  :lol:
daozen
#6
Quote from: mexicanyella on May 12, 2012, 01:49:45 AM
Thanks Anyone!
Man! you are awesome! Well, the thing with the love for my amp's sound is that I don't really know if I could get an even more beautiful sound from a fender amp. It would be weird if I didn't, no? I have used another brand amp I can't remeber, but it wasn't a know brand and I was still loving the sound that came from it setting it up like I like it (cranking up the od and taking out a bit of treble). I guess I'm going a bit through the phase you are talking about aswell, thanks for pointing that out!
I play alternative pop rock I guess, about 30% clean reverb stuff and 70% overdriven delay stuff. With my overdriven stuff I try to emulate the "hendrix band of gypsies" sort of sound adding reverb and delay. I always use the bridge pickup and keep the tone knob at 1-2 most of the time. I will be playing mainly chords as I'm the lead singer, but I'm also the lead guitarrist so I do play lead solo stuff aswell. My drummer is a metalhead turned pop, so he plays hard, which is not of my absolute likeing but we are a high energy band anyway, I hope. I want the amp for playing on my room and playing at small-medium sized venues, large venues need miking anyway right?
I'm liking the sample, nice southern tone! yeah that's what I need a cutting tone, altough I would also like to hide a bit when it comes to chords.
I really wanted to avoid "pluggin" my music, but I've been helped already and in order to answer the type of music genre I will be playing: http://www.facebook.com/daozenband/app_2405167945
I don't sell anything anyway, but I guess some might be interested in the sound of what's to come for the Guatemalan rock scene, lol. The songs are not entirely representative of what the band will be about, we'll be playing a bit heavier stuff. (recorded using a usb mic, johnson guitar and amp and effects pedal)
Radiohead is one of my main influences but Greenwood's sound is not what I'm after, too twangy, whats a red-knob? by dimed you mean everything on 10?
I hadn't thought of unpluggin the pedal, not sure I have the balls to do so, but I guess it's what will say what I need. and yeah miking seems like the way to go, I will keep all of your guidelines in mind next time we rehearse!
Again, thanks for your lengthy response, you have no idea how much it helps!  :dbtu: thanyou!
daozen
Quote from: phatt on May 12, 2012, 02:34:32 AM
Hello daozen,
thanks! I think I will do that! It does seem I need a small amp, I'm just a bit afraid of going, too small? It's no big gig in mind, and you lost me with linking 2 amps together, never heard of that.
daozen
Quote from: mexicanyella on May 12, 2012, 09:45:42 AM
Great Idea! I will post some pics this afternoon!  :dbtu:
mexicanyella
I'll check out your band clip later when I can turn up the computer speakers and rock out without my wife looking at me like I'm retarded. But in the meantime:
Don't assume a Fender amp is what you need to amplify a Fender guitar. Some would argue that a Fender guitar's bright, single-coil sound is best served by a darker, thicker amp...or that the fatter, porkier sound of a two-humbucker Gibson is well served by a bright, loud, fairly clean Fender silverface amp, like a Twin. But that stuff is all subjective and depends heavily on the context you're hearing it in, how the band interacts, the genre of music, the player's approach...it's a sea of question marks. You just have to try stuff and eventually decide what serves your approach. But don't rule out what you already have, at least not yet.
Amps and guitars are tools that make sounds, and all sound combinations have an application somewhere, with somebody. One of my favorite guitarists ever is Ty Tabor, from King's X, who played for years and four albums with one of those weird early 80s Strat Elites with the odd active pickups, into the preamp section of an old Lab Series L5 solid state amp, through a graphic EQ and various delay effects into a big Crown PA power amp driving multiple 4 x 12 cabinets. That rig had to be the result of a lot of experimenting and chasing a sound he heard in his head...while not being concerned with brand names. Besides, the notion of "Fender Amp" covers a LOT of ground. Early tweed Fender amps sound warm, loose (some might say sloppy and out of control) and fuzzy, like Chicago blues guitar or in extreme cases, Neil Young when he's rockin out. But then there's super clean twangy Fender sound like what country guys might do with a Telecaster through a Deluxe Reverb or a Twin Reverb. Or you could get a Performer 1000/Roc Pro 1000 and have intense buzzy metally distortion if you were messing around with one of the later hybrid amps like a Performer 1000/Roc Pro 1000, etc...you kind of have to try stuff and listen on a case-by-case basis.
The linking two amps together thing...it's one approach to getting more volume by using multiple small amps instead of a big one. There are various reasons you might do this; in my case I happened to have a pair of little old tube amps I liked the sound of, and while one of them wasn't quite loud enough to gig comfortably with, two of them were just right for most of the St. Louis clubs we were able to get gigs at. Now, those amps were pretty much one-trick ponies...they sounded great to me at one specific volume level....too low and they sounded boring, too loud and they sounded too sloppy and out of control, and the right level was too loud for basement practice and not quite loud enough in a big room. So, I ran my signal through my couple of pedals and then a little Boss reverb unit with stereo outputs, and ran one output into each amp. I didn't need stereo reverb at all, but the stereo outputs were a handy way to split my signal into two amps. A lot of chorus pedals and floor multieffects units have stereo outs too. And when the tube amps crapped out once in awhile, I'd have to substitute my practice amp--Peavey Audition 20--which was not loud enough for a gig by itself, but if I stereo paired it with my friend's Crate GX15, it was just loud enough to get by while the tube amps were being fixed. Since at that time I was amplifying the sounds of pedals and the amp was just adding a little distortion to that, either way worked for me. The amps alone were fairly clean.
Later, in my next band, I needed a different sound to blend right and I'd settled on a lightly distorted sound from the Peavey--like what you hear on the song link. When I needed to get that sound at a louder level for gigs, I slaved the Peavey into a second amp, by taking a line level signal from the Peavey's line-out jack and sending that to a different amp. Then the second, "slave," amp got the job of amplifying the Peavey's signal to add more power stages and speakers but retain the tone I liked from the Peavey. The best way to do this is if the slave amp has a line in jack or an effects return jack for the effects loop. That way you are bypassing all the controls on the second amp since you're bypassing its preamp, and its performance is controlled from the preamp in the master amp. Only one set of knobs to turn.
But in my case, I used one or both little tube amps for slaves, which don't have effects loops or line in jacks. The Peavey's line out signal is low enough in volume that I could just plug it into the tube amp's instrument input and be conservative with the volume settings so as not to overload the tube amp's input with too hot an input signal. The slave amps didn't have to work THAT hard anyway; the Peavey was cranked pretty hard and the slaves were just helping a little bit, since the band itself wasn't that loud. (Most people would probably slave a small tube amp through a larger solid state slave amp, since they'd want to preserve and amplify a cool-sounding but too-quiet tube distortion. In my case, the tone I wanted came from a solid state amp and I just happened to have a pair of little tube amps to use as slaves...so I was bass-ackwards about it).
Once I/we get a look at your little Jo-...I mean your amp, we can probably suggest some ways to use it for live...
daozen
ton of info! but it's all good so I'm taking it in! Well here's my little johnson. I can't believe this amp has as good of a sound as a frontman would so I'm still thinking of having myself the frontan 212 or 25 but would the 25 be enough? I'm also thinking about the clean tones I could get from the 212r, I feel I would loose a range of sound if I use the 25w one, but at the same time I could get better or more useful overdrive. Plus, I'm getting the deluxe player's mexican and some reviews say those vintage noiseless pickups are maybe too warm, so a bright and clean fender amp would suit it. Still the only way to know will be once I effin get it. Anyway, here's my setup!
mexicanyella
I don't know that amp, but it's got a line out jack on the back...if you decide there's a tone there that you can't get from other amps, you could connect that line out jack to another amp's line in, power amp in or effects return jack and get the little Johnson sound at higher volumes.
Or, you could buy a used rackmount power amp and drive it from your Johnson's preamp, in order to power one or more guitar speaker cabinets.
Or you may be able to hold your own with your bandmates, volume-wise, just as you are right now...at least in rehearsal. Try it and see.
Be wary of online reviews saying pickups are too warm or whatever. It's totally possible that you would disagree; always try and listen for yourself when possible.
Is that F-hole guitar an Ibanez Artcore-something? Looks nice.
daozen
Quote from: mexicanyella on May 13, 2012, 11:51:52 PM
Thanks man, I think I will go and see what I can get when I finally get the guitar. I doubt I wont find something I like that's better than this and yes, it's an artcore 75 something, Sound's nice but not as much of a soloing machine as the strat, so I can't wait for the new one! Thanks again! I'll let you know what happens.
Moby
+1 on using the line out.
I'm no expert but that doesn't stop me from sharing my limited experience.
I use a little 20watt Mustang I when playing at my church.  I face the amp toward me and use it as a monitor and put a mic on it for the house mix.  Sometimes we have a choir, six ensemble singers, a brass orchestra, drums, bass, piano, electronic keyboard, two acoustic guitars, and a percussionist all together on stage. I NEVER have trouble hearing myself and the little amp is never cranked past 3 or 4. You could do a similar setup and plug your line out into the house mix (assuming there is a house mix, if not then forget everything I wrote).
Where I play nobody uses big amps and the mix in the sanctuary is excellent. The monitor mix is never that good but it's workable and better than when I played with rockers.
That type of setup may not go over well in a club even though it sounds better. Folks in a club usually expect the music to be blasting. They'd probably think the music sucks if it's not hurting their ears.  :loco
mexicanyella
#14
I would like to relate an experience that supports Roly's post.
Two bands ago, we lucked into playing what was then St. Louis' largest live music club...the now-defunct Mississippi Nights. Somehow, we got on some backup band call list and when an opening act for a weeknight show bailed for whatever reason, the club started calling bands on the backup list. I'm not sure how many tiers down we were on the list, but we must have been the first ones that said "You bet! We'd love to!"
We practiced about 15 minutes from the club, which was about 60 miles from my house. I was already in town, so from my point of view it was, if nothing else, a chance to have band practice through a really nice sound system with subwoofers and good monitors and whatnot.
This was a time when the two little vintage tweed Valco tube amps I paired up for live gigs were both laid up with problems, so I had to borrow a friend's Crate GX15 to pair with my Peavey Audition 20 and hope the two together had enough volume to be heard by everyone on stage. At the time I was running a ProCo Rat II at a low gain setting but on all the time, through the speaker simulation filter of a BBE DI-10 d.i. box, into whatever amp. A DOD boost pedal in front of the Rat kicked the gain up for solos. I split the signal to the Peavey and Crate through a crappy-sounding old Boss digital reverb, which I mainly used as a signal splitter. I set the amps to go as loud, clean and flat as they could without too much breakup--on the scooped-sounding Crate, this required the mids to be set kind of high and the highs/lows to be set below halfway. It seemed to work pretty well at our practice space, so we loaded up and headed for the club, where we discovered that...
...the main act we were opening for was the Gigolo Aunts, who were from Boston (I think), were touring and were pretty into slick tube gear. The bass player had some old Traynor tube bass amp, and the guitar players had a Matchless, a Fender (Twin? Deluxe? can't remember) and really nice vintage guitars. I go up there to set up with my frankenstein strat-like parts guitar, a couple of pedals and a couple of practice amps, dwarfed by the gear behind it. The Gigolo Aunts guys came by and made some carefully deadpan remark like "Those are nice," and walked off. The soundman came up and said, "Soooooo...what are we planning to mic here?"...like, are you wanting to share the Peavey tone or the Crate tone with us tonight? I told him, dead serious, that the Peavey was my main amp and the Crate was just there for stage volume. He said "oooooookayyyyy" and miked me up and left.
At that point I was starting to have some doubts but when we tried it, it was just loud enough to work with, and about halfway through the soundcheck song we were doing the monitor mix came together and it sounded great...probably 85-90% of what I was used to from the tube amps, which tells me that most of my tone was coming from the pedals in those days. But the gig came off fine, almost no one showed up but we played well and the Gigolo Aunts came out and kicked total ass to a mostly empty house. As we were loading out the soundman waved me over and said to his surprise the guitar sound was great out front and very easy to place in the mix, since there wasn't that much coming off the stage competing with the house system.
So, yeah...little amps can work. In my case, it helped that we were a fairly restrained band, volume-wise, being organized around and in support of an acoustic guitar-playing singer. But it worked great that night and in the places where I got to crank up and blow, there was enough sound from behind me and from the monitors that I didn't feel any lack of punch at all!
