Baldwin C-1
Started by clguy, February 15, 2012, 08:44:24 PM
clguy
I have a Baldwin Professional that has "smoked" two of the six (6) R47 wires that are soldered on the lugs bolted across the rear of the heatsink of the TO-3's. What is going on? and what would replace them with?(after I fix the problem).
A knurled nut & 8-32 bolt fell out from where it was wedged between the Ch.2 board and the chassis (Ch.2 had not worked before - zero/nada). Now both channels "work", but are weak & distorted.
Quote from: clguy on February 15, 2012, 08:44:24 PM
We'd need to see a schematic or at a minimum, some good pictures of the board, to help.  Get us those and we'll help as best we can.   :tu:
clguy
I have two TO3's with shorts (no resistance) from the emitter to case.
There is base & emitter voltage to the small transistors and output from all but the Ch.2 fed from the volume pot. (Jim002) and output board with orange dot (Jim001).
clguy
My attachments are not coming through. The schematic I had was baldwin_schematic.gif from Teemk on Sept.14,2008
clguy
Can I use 2 watt flame proof metal oxide power resistors to replace the blown 0.47ohm wires (fusible links)? Do I need more wattage like a cement ceramic?
Will Motorola MJ15004 or MJ2955 replace the shorted 36312 RCA's?
I think the 500uF 5WV in the output stage is shorted and want to use a 50 VDC to replace it.
clguy
There were 7 fusible links (.47R) on the rear of the amp. One was missing when I got the amp. I soldered in wires the same dia., turned it on and now have 3 smoked fusible links instead of 2!
Without the "wires" (=no smoke) the voltages seemed to check out (the first TO3 had +30 and the other 6 had +40).
The speakers may have been series wired (4+4=8). They were unplugged when I got the amp and I put white-on-white & black-on-black. Could this have lead to such a disastorous result??
I am now using my Kustom 4060 pa amp to play guitar (with the Baldwin 4 ohm speakers - one on each side).
The original wiring was 2 x 4 ohm speakers in parallel for 2 ohms total, so that was fine.
Problem is you have shorted transistors and being germanium they are both cr4p and very expensive.
If you dare, you can modify it for silicon , don't know your degree of commitment, *or* you can drop that power amp altogether and mount there 2 chipamps, each of them driving one speaker.
Post a couple sharp well illuminated pictures showing the full chassis both inside and outside to have a general idea of the available space.
Is the original amp built on perfboard or is that a homemade repair?
IMPORTANT: the PSU is not shown. It must be a simple circuit anyway.
We need to see it because we must rewire it to get +43V instead of those -43.
It should be no big deal but need the info anyway.
They already have +22V which must come from *somewhere*.
*or*, Plan C, you may also get a modern PSU; say, +/-  32 V, feed an LM3886 from it , which would drive the 2 speakers in series (50 excellent Watts into 8 ohms total) *and* still feed the preamp.
Be careful with your Kustom 4060; you are loading it with 2 ohms total, I doubt it'll like that. Use these speakers in a single cabinet and *always* in series or you´ll needñlessly blow the best part of what you habe: 2 original unreconed (so far ;) ) Vintage Jensens.
Hey !! I would sell these for good $$$ to Vintage lovers and buy 4 modern ("less desirable" ) Eminence legends or similar or 2 speakers and new guts for the Baldwin.
But if you burn them (easy to do) you have nothing.
clguy
I found an old schematic. It shows the NPN's with the 0.47 fuseable links across from the emitter to collector? Could the TO3 sockets or mica gaskets be causing the "short"? There is green (CU) on the connections.
Is an ASZ1015 a replacement for the old RCA TO3's?
I bought the Baldwin for the speakers. I needed a 4 ohm for the KPM4060's stereo amp (60 watts RMS @ 4 ohm). I am not sure I need to spend more time or money on the old amp but wanted to learn more and see if I could nurse it back to health.
clguy
Here is the schematic. It is hard to read and may be the single 12" model.
Dear clguy, your Baldwin speakers are not suitable for your Kustom KPM6040.
Sorry.
clguy
I found the schematic with voltages. I have no voltage at one side of the driver transformer to 3 TO-3's (beside the two germaniums that are shorted emitter/case).
The transistors (7) will be $50 including fusewire and shipping and the transformer $35 more.
Quote from: clguy on April 12, 2012, 06:32:03 PM
Sounds like a good time to consider re-powering the amp with a chipamp circuit.  chipamp.com has LM3886 kits that would do nicely.
Agree and add: *worst* case, if there is a wiring error or some other Murphy's Law manifestation, eaqch new LM3886 will cost a few dollars, and they are *always* available, while blowing those Germaniums again will bankrupt you.
Short time ago I repaired a very loud Behringer 2x12" combo which, go figure, used 2 x LM3886, each of them driving a 12" 4 ohm "Bugera" speaker, which (small World it is) is made by .... Jensen !!! Notice any similarity?.
Killer sound.
http://music-electronics-forum.com/attachments/18085d1334061834-behringer-gmx1200h.pdf
Look at page 3.
If you decide to do this, you will have to mod the power amp slightly because they are meant for split supply and you have single supply (add some caps ) but nothing too difficult.
But *please* post a picture of how the power transistors are mounted, to check any heatsinks and available space, to see whether you can fit a new power amp there or not.
I have saved tons of "old/unrepairable" amps which were so either because of parts unavailability (germanium transistors or obsolete ICs) or because repair cost went above a used one on EBay, by "heart transplanting" a new power amp .
Sound remains the same because it comes "cooked" from the Preamp.
clguy
Thanks for the second look. I will use a chip amp to replace the output amp on the Baldwin.
The space where the capacitor/holey board/ output transformer was is 12" x 4" x 2" deep. The Channel 2 board with tremelo is on the other side and the Channel 1 is on the rear side to the left of where the new amp will be going.
I will need point to point instructions for hooking it up. The LM3886 can be purchased assembled with heat sink for under $20. The heat sink will stick out the back if
I think the schematic shows +43v (pin4) & -43v (pin11) or +32v (pin3) & -32v (pin10) from the existing Baldwin power supply on the bottom of the amp. The LM3886 wants 20-28v?
Will the old light bulb limiter be saved?
The LM3886 can use as much as +/-47v, but I wouldn't run it that hot.  I'd shoot for about +/- 30-40v.
