November 02, 2025, 09:03:57 PM
seeking direction for my first SS project
Started by mmorlan62, January 13, 2012, 11:38:45 AM
mmorlan62
Hi everyone,
This is my first post after absorbing as much as I can.  I could use some advice and direction for my first project.
I'm putting together a SS amp project to share with my young nephew and was finding myself torn between some options.  We're building a couple of practice amps so I can teach him a bit about electronics and we can play together without driving the family and neighbors crazy - so that means low wattage but with a bit of gain/drive.   :)  My nephew has an inclination to also play bass so an amp circuit that can handle that would be nice.  I'd like to make my amp stereo to play well with the BOSS GT-10 board.
Options I've considered include:
o the 1watt RunOffGroove Ruby circuit (could you share the same vol/gain potentiometers with two LM386 chips or would there be some "cross-talk" between the chip inputs?) <EDIT> Or, duh!  I could just use ganged pots.  </EDIT>
o the 6watt Stereo Amplifier cobbled together (but untested) by Paul Nelson using the TPA1517NE.
o the Elliot Products 20w amp project at http://sound.westhost.com/project72.htm (although that's getting a bit too powerful and not designed for overdriving the amp.)
<EDIT>
Also:
o the Tiny Giant Amp - http://musicpcb.com/pcbs/tiny-giant-amp/
o and this untested 2x11W stereo amp submitted years ago and never commented on:
   http://www.ssguitar.com/index.php?topic=1325.0
</EDIT>
What other choices are out there without getting too hot on the wattage?
I have competence with reading schematics, PCB printing, and part specifying but not quite the knowledge to design something from scratch.
(Oh, and it looks like I'm going to spend some time reading Teemu Kyttala new eBook.)
Thanks for any thoughts you may offer.
Michael
When using SS amps Most of the OD effect is all done in the preamp section so any half decent SS Amp will be able to get OD/distortion at low volume levels.
You will need At least 20 watts if you wish to use it for Bass other wise the signal will be mush at any level.
The 20 watt ESP circuit will only just barely cope with Bass guitar.
Have fun,,Phil.
