LM3886 Guitar Amp Build Report...
Started by RDV, July 16, 2006, 08:10:06 PM
RDV
...again.
About a year or so ago I ordered a chip from National Semiconductor and built my 1st chipamp to use as a practice guitar amp. I followed the schem from the datasheet and guessed at a PS from reading at Rod Elliott's website. I built all this on perf but made a bunch of rookie mistakes cause I was too cheap to buy one of Brian's kit's or boards. A series of calamities culminated in the utter destruction of this 1st amp when the charged heatsink made contact with ground resulting in a very firey smokey end to that 1st chip. I had made the mistake of buying the uninsulated version and then didn't follow good advice to insulate it myself.
So now, I acquired a PCB set from Joe and set about doing this right. I even used the recommended polypropylene caps this time. It sounds really good and doesn't even get warm so far whereas the old one stayed hot due to oscillation caused by my horrible perf layout. I'll try to get some pictures up within the next few days.
The preamp I used was already there and is well documented. It may not be for everyone but I like it a lot.
RDV
Thats great you are getting this thing going RDV!  I can't wait to see some pics of it all together.
trevize
do you have samples of this amp with clean settings? I saw the diodes in the end, probably ther limit pot makes an emulation of tube compression, so you can have crunch sounds too, right?
How does this preamp takes pedals?
I'm really interested in how this preamp work altough i would probably change the tone stack (never been familiar with the vox one i always end with bass and treble on 10, i suppose i need mid controls).
RDV
Quote from: trevize on July 17, 2006, 03:02:01 AM
Yes. http://fatboy.ssguitar.com/index.php?dir=Samples/Chipamp_Samples/&file=Bminor.mp3
It gets a little crunchy but mostly it just keeps the signal limited so as to not overload the chip.
Very well IMO. Here's some samples:
Uglyface> http://fatboy.ssguitar.com/Samples/Chipamp_Samples/Uglyvox.mp3
Transistor Obsidian> http://fatboy.ssguitar.com/Samples/Chipamp_Samples/MRB%20Obsidian.mp3
PT-80 Delay & BMP> http://fatboy.ssguitar.com/Samples/pt80-3.mp3
If you don't use the tonestack, you won't get the MRB which is at the heart of the tone. It stands for MidRange Booster. It requires a wah-wah inductor.
HTH
RDV
trevize
very nice clips! The clean sound is good and it works great with pedals, i do like the Obsidian clip!
Thank you RDV!
Stompin_Tom
So, here's a noob question... RDV's preamp requires 15v... How do you power that from your poweramp transformer?... or do you need to have another transformer for that (or a custom job with more secondaries)?
RDV
Quote from: Stompin_Tom on August 17, 2006, 02:42:07 PM
I used a transformer that had multiple secondaries that R.G. Keen found for me on eBay. There are a # of ways to do it though. A good place to look is Rod Elliott's website. He shows a way to do it using Zener diodes and resistors. Regulators are another way. I used a seperate transformer at one point when I was trying 9volt circuits.
http://sound.westhost.com/project27.htm
The project above shows how Rod used the zeners to bring 35v +/- to 15v +/-
HTH
RDV
Stompin_Tom
ah... so think of it as a wall wart. I mean regulate or whatever you have to do to get the voltage where you need it. Thanks!
