October 25, 2025, 09:28:43 AM
Any advice for building a 2 button footswitch?
Started by LJN, April 26, 2011, 01:56:50 AM
LJN
Hey,everybody. I have a problem, and this seems to be the best place to find the anwer. My old sears amp is supposed to have a footswitch, But I don't have one for it. It's not really an issue until I need the tremolo, then it becomes a real problem.I know that it requires a stereo plug and two effect switches, but I'm really not sure about the rest. Any advice on building a two button footswitch?
If it sounds good, USE IT!
Quote from: LJN on April 26, 2011, 01:56:50 AM
I've not built one myself.  But from what I remember reading a while ago they normally just ground the connection between tip 1 and sleeve and tip 2 and sleeve.  You'll need to check with your amp if you need a momentary switch or a latching switch.  This is easy to check, plug in a stereo plug then play with the wires crossing them till they switch the channels.  Then just wire the switches to do what you had the wire doing.
LJN
Thanks for the advice. I believe the footswitch for my amp was for switching the reverb and tremolo on and off.
crane
If it is not a million channel/million feature amp then most probably you will need latching switches. In most amp designs if you put a LED in series with resistor paralel to the switch - you will get a footswitch with LED.
LJN
Thanks, I'll have to see if I can find some switches. I wasn't going to use LED's because I want to keep it simple. The original one didn't have them, but it does seem like a good idea.
LJN
Quote from: joecool85 on April 26, 2011, 09:51:21 AM
[/quote]
I would just try to find one, but they're hard to come by and usually cost more than they're worth. I'm tired of finding old amps and every one of them is missing the footswitch. I'm certain that what it does is each switch grounds out the effect that it's assigned to. at least that's what it looks like.
Quote from: LJN on April 28, 2011, 03:02:25 AM
All you need is a generic 2 channel switching switch.  Musician's Friend sells them cheap.  I think under $20.
LJN
That's alot cheaper than the route I was gonna take :o
I was gonna use the stompbox switches, a stereo jack, and a cut-off 3 prong cord. I'll definitely look into that! :tu:
Thanks alot, Joe.
Quote from: LJN on April 29, 2011, 02:34:07 AM
Thanks alot, Joe.
Looks like it's $25 for the cheapest one and it says Vox on it.  You could always paint it if that bothered you.  But yeah, once you bought the two switches, jack, enclosure and cord, you might as well just buy the thing.  Course if you build it, it will probably be more rugged than a store bought unit.
LJN
I built the footswitch today, and it works great. I got the parts at my local radioshack. It costed somewhere around 10 dollars, and I couldn't be more satisfied. :tu:
Quote from: LJN on May 07, 2011, 03:48:49 AM
What'd you use for a switch?  I didn't think they had any stomp switches there.
LJN
I used two cheap push on/ push off switches. They costed $1.99 each. They're plastic, but they serve their purpose quite well.
Quote from: LJN on May 09, 2011, 04:08:34 PM
Ah, be careful how hard you stomp them that's all.
LJN
No need to worry about that. I don't stomp on any of my pedals. I use just enough pressure to turn them on and off. these switches that I used for the foot switch are very easy to push. they're pretty sturdy for plastic too. I also labeled it. I found out a way to givethe letters an aged appearance. I used microsoft works to print the words, and put clear tape over them while the ink was fresh, then I carefully pulled the tape off and it transferred the letters to the tape. When I put my labels on, the letters looked old and faded. It looks as good as it works. :tu:
Dimi Pana
Hey, LJN !
Sorry to revive this old thread but you got me intrigued!
Any chance you could post a nice picture or two of your DIY foot-switch. I have the same problem as you.
It will be much appreciated.
Thank you !
