October 20, 2025, 04:21:14 PM
Guitar preamp
Started by P3To, March 04, 2011, 07:04:22 AM
P3To
Hi,Could you suggest me a good guitar preamp, but with Bipolar transistors or ICs. Thanks
#1
I'd suggest the Dean Markley K20-X preamp.  Sounds great, has a 3 band EQ and uses commonly available parts.
There is a vero layout for it here:
http://www.ssguitar.com/index.php?topic=1885.msg12904#msg12904
The schematic for the whole amp is here: http://deanmarkley.com/Info/LegacyAmps/Schematics/D1515.pdf
**EDIT**
Please note, it does use a 500 ohm potentiometer for the Mid EQ.  You can get away with using a much more common 1k potentiometer without issue though.
