December 04, 2025, 08:08:12 AM
Heatsinks for your poweramp
Started by joecool85, April 05, 2006, 07:37:26 PM
rowdy_riemer
Not talking about making pennies, but using pennies as a source for zinc to make zamak. :)
rowdy_riemer
Sorry, JM, I might have misread your post.
You *read* it right, but I think you missed the
rowdy_riemer
Hehe.
It seems like I figured out one time that using pennies as a source for zinc would cost about twice the market value for zinc. I imagine the negligible amount of copper plating wouldn't hurt anything. I think some Zamak alloys even contain a bit of copper. But it certainly would be cheaper to find scrap zinc.
spud
Hey I'm new here and I'm wanting to build a chip amp but when I started doing some reading and I realized that a heat-sink would be essential if I wanted any real power.  I did some searches and I found these guys:
http://www.heatsinkusa.com/storename/heatsinkusa/ViewDept-269591.aspx
Has anyone used this vendor?  Also, what size would be appropriate for a LM1875 chip amp implementation running about 15 - 20w? Probably 24v or so.  I figure the small 1 inch one would suffice since it's rated at 2.15o C/W/3 or am I not understanding the rating they give?
Some background: I've built a few pedals (BSIABII, Double D) and have prototyped a few others (Plexi-izer, UBEscreamer, Hot-harmonics), finished 2 tube amps (AX84 HO and a Firefly) and still have 1 on the bench (a 5E3).  I've been considering taking a pedal like the ROG DD  and mating it to a chip-amp for some time but never taken the plunge.  I've got a bunch of parts (Caps, Res, Trans, Op-amps, etc) I've collected (I try to buy in bulk) and I started looking around for amp chips and I realized I needed a heat sink - but most are pretty pricey for what you get (did I mention I'm a cheap) which is a hunk of metal - but I found these guys and was wondering if this was a good source and what size(s) to get.   Optionally, if anyone can help me with doing the calculations to figure it out myself, that would be great.
BTW - this seems like a real cool site and I'm jazzed that I found it.  Been reading a lot of the threads - great ideas and projects.
Thanks -
Jim
rowdy_riemer
I know this isn't related to the OP, but what did you think of the firefly? I'm kinda considering building one.
spud
Hey - well I like it, here's my implementation of it - called the Small Fry to avoid confusion with the original:
http://s252.photobucket.com/albums/hh7/spudjds/Public/Builds/AMPS/SF/
I added a tone control (By-passable) with a scooped switch.  Also added a switch to allow use of a ECC99 in addition to the 12au7 - rest of it is stock.  I recently re-did the grounds and I have a problem to debug with the boost - no work.  Oh, well - I can't leave well enough alone  ::)
My mods are all documented in the layout and the schematic there.
Jim
rowdy_riemer
Hi.
You somewhat misread the data but no big deal.
That last "3" means that this heatsink provides those 2.5ºC/W for a 3 inch length; they do not state it for a 1" length nor provide the dissipation vs.length table, which amazes me.
Anyway, on experience I cantell you that the actual value will be around 4ºC/W and even more important: it will be enough for a 25W chipamp.
In fact I use a slightly better 20 fin , 2 inch length one for my 100W amps with excellent results.
You will also be able to use a piece of 1/16" flat aluminum sheet, 4" by 6" size, which you may scrounge for even less money.
spud
Hey JM thanks - so I can go to Home Depot and get a 1/16" sheet and cut it to 4 x 6" and use that for the LM1875?  Wow - cool idea.  I like that. With about a thicker piece like 1/8" - would that mean a smaller size?  By what proportion?
WRT to the heatsinkusa product: so I can use a 1" sized one for the LM1875 or does it need to be 3"?   I may go with the 5.x size if it means I can get smaller piece - it's rated at 1.15 vs 2.3 for the 4.x" one I linked.
So is there a formula to calculate this or some rule of thumb to go by?
Thanks for the info -
Jim
Basically yes.
Aluminum is a great heat sink material.
I make my own chassis and have always used aluminum, so by just bolting transistors or chips to the chassis (using proper micas, grease, etc. of course), I have "free" heatsinks. WOW !!.
Your 1/16" is fine and still can be bent without heavy machinery.
You may mount a flat sheet with spacers or bolts and nuts "in the air", remember you want free flow of air around it, but being able to bend it in an "L" shape makes mounting easier.
1/8" will work better because heat across it will be more uniform, good, but you still need a certain surface because the last link of the chain is heat transfer to air.
Commercial heatsinks have the added advantage of providing a lot of surface in a smaller size.
There are formulas, which I have not found very accurate for everyday work, or empirical dissipation tables provided by heatsink manufacturers.
rowdy_riemer
The first thing I noticed when I first opened my Crate GFX-212 was that the transistors were mounted to the chassis.
scooperman
for bench testing circuits, an old lawnmower or motorcycle finned cylinder head works fine as a heatsink.  Bob Pease used a VW cylinder head when testing new chips.
Quote from: scooperman on March 28, 2011, 09:11:11 AM
Great idea.  You could use it as a final product I'm sure as well, albeit much heavier than a more traditional solution.
spud
How about an old CPU heatsink from a dead computer?  Would that be usable given that you have some thermal goop to put on there.
Jim
