How solid state amp works and MG15 mods
Started by -W-, June 19, 2010, 01:19:44 PM
-W-
Hello, I want to ask how solid state amp works I know basicly how tube amp work and I built some pedals.
Also I would like to know if there are any mods for mg15 like changing to another dist, adding footswitch, fx loop, improving the cleaned and such stuff.
Search here and download Teemuk's excelent SS amp book.
You might want to download and read first (search for it) Jack Darr's book, which gives a lighter but wider focus on guitar amps in general, including tube and transistors, and then advance further through Teemu's.
You could also Google "how a transistor stage works" and "how an Op Amp works", as well as "how a tube amp stage works", and then consider them "building blocks", any amp is made of combinations of these.
Jack1962
great advise as always from J M , but to answer the mod question , yes the MG15 can be be modiified (did I spell that right lol) just like any other amp (tube or sollid state) however , the question you really need to ask yourself is it worth the time and money to do so.
                                                    Rock On
DJPhil
Quote from: J M Fahey on June 19, 2010, 11:05:40 PMYou might want to download and read first (search for it) Jack Darr's book, which gives a lighter but wider focus on guitar amps in general, including tube and transistors, and then advance further through Teemu's.
I wanted to hold off on a first post until I had something useful to say, and boy did it take a while. :D
I had a bit of an adventure finding Jack Darr's "Electric Guitar Amplifier Handbook", so I thought I'd post a link in case anyone's struggling trying to find it.
http://www.filestube.com/3fb5efb6f207ba4903ea/go.html
Hope that helps someone  :)
Jack1962
Went to your link there for the Jack Darr , book they want you to sign up it is a pay site
The book can be found from multiple locations. Here it is splitted in chapters:
http://www.diyguitarist.com/Misc/J_Darr.htm
I still haven't found a version that would include the schematic resource of the actual printed book.
QuoteI still haven't found a version that would include the schematic resource of the actual printed book.
I don't get it either.
In theory, that's because "everything can be found on the Net" , which simply is not true.
It's a *very* important book for me because that's why I got into this.
I started to build what I saw there.
We're talking 1969 here.
My first Guitar amp was the Gibson GA ¿5? : 1x12AX7+1x6V6.
Boy, was I proud!!
Then I made the ¿blackface? Bassman, the first amp I sold to an important Band, and then my version of the Ampeg BT15: the preamp on stripboard and a straight-from-the-datasheet Motorola 120W power amp, with MJ802 and MJ4502.
As a side-note: believe it or not, I made those SS amps on eyelet board !"
As a 1972 example (a 200W into 2 ohms power amp):
Even more amazing: it *still* is in daily use. (Maybe that's what has kept it alive)
Jack1962
Yes J M , it is a common believed that everything can be found on the internet , and it is far from the trueth. However for those of you that are serious above building amps or even working on them , the Jack Darr book is a must, I didn't discover it until I had all ready been thru college and working in the field for some time , it sure would have made things a lot easier if I had. Now back to that fine amp of JM's yea it being used in daily life is probably what keeps it alive it does me .  :lmao:
                                                Rock On
Not only is it assumed that everything is on the internet, the corrollary is that if a company doesn;t show some item on their web page, they must not have the item.
Well, Enzo usually suggests callingCompanies (Ugh !!!   :loco)  ;)
One of these days, he'll suggest buying in a shop !!! over the counter !!!! maybe even paying with real money !!!!!  :duh
DJPhil
Quote from: Jack1962 on June 24, 2010, 05:04:46 PM
Sorry it took so long for me to get back, things were interesting here in a Chinese curse sort of way for a while.
Aarrgh! I hate those sites sometimes. I just tested it again and it works ok, but you have to know how to dodge through all their crap.
I put up a pair of pictures to guide you through. I'd just attach the pdf but it's 4.25MB so it's too large. I also uploaded it with rapidshare's free service, but it'll go away after 10 downloads. Just hit the "Free user" button. If all else fails I can email it, just send a private message.
Hope that helps :)
