headphones into extension speaker
Started by nysteen, December 24, 2009, 08:32:18 AM
nysteen
Hello
I have a Peavey Delta Blues amp and I would really love to be able to plug my headphones into the amp and play silently, but it does not have a headphones jack. Can i somehow plug my headphones into the extension speaker jack and mute the amp itself so I only get the sound in my headphones?
I'll assume it's a Tube Amp? in that case steer away from headphone ideas :duh
You can do it but a lot has to happen and the complexity and cost will hinder your progress.
fretknowmore
possibly consider a dummy load.
an 8 16 ohm resistor of huge wattage 10000 watts
and rig that in with another resistor to the headphone jack
the rig would be external but it is a way to jack sweet tones and not at that loud volume
and yeah when it's cranked you hear music coming right from the resistor.
Minion
If it has a Line out then you can built a simple headphone amp circuit and listen that way or even buy one of those cheap behringer headphone amps and use that ....
Remember to plug a shorted plug into the power amp in to mute it or you will still hear it.
Anyway Phatt's suggestion applies: tube amps don't have much use for headphones (unless you drive them full tilt into an attenuator/silent speaker thas has its own phone output) because you lose much of the "magic".
You might plug into a SS practice amp headphone out and hear about the same.
