November 13, 2025, 01:35:45 AM
gretsch nashville 7154
Started by shovelheadsixsix, October 18, 2009, 06:09:15 PM
shovelheadsixsix
I have a 1968 gretsch nashville soild state amp .When I use the built in  echo or the tremolo effect the amp will thump continuously without strumming a note.What is wrong.
What's money? A man is a success if he gets up in the morning and goes to bed at night and in between does what he wants to do. Bob Dylan
Grounding problem. Usually "mechanical" meaning rusty/worn/corroded contacts (do your PCBs use some kind of connectors, or crimped connections?) or maybe some loose nut in the grounding screw.
I think you get what I am pointing at.
Might also be old/dry filter capacitors. Statistically, these are the most likely culprits.
Third in the list might be old/rusty/dirty pots , jacks, etc.
shovelheadsixsix
Thanks. A ground problem was my first guess.I just got amp it still has a 2 prong plug  a ground plug is going to be one of my first fixes.Hard to find any info on this amp.any one have schematics?
shovelheadsixsix
repalaced caps today and still have the hum.now I will  try and figure out the ground problem.
