December 03, 2025, 02:15:39 AM
Ohms question
Started by Talkboxert, September 24, 2009, 07:19:53 AM
Talkboxert
Hey there,
I have a (newbie) question about my Fender vintage tube headf (PA 100).
Originally designed as a PA system with 2 speakers, this baby has two 8 OHm outputs.
My question: Could it harm the amp when I only connect 1 of those outputs to a 8 Ohm cabinet? Or should I then use a cabinet of a different Ohmage?
A schematic can be found here: http://www.schematicheaven.com/fenderamps/pa100.pdf
Thanx
polo16mi
Hi:
My 2 cents answer...
If the output says that is 8 ohm, you could conect to it any cabinet or speaker that have an impedance of 8 ohm or more than this, i.e. 16 ohms, no matter the size of the speaker or cabinet.
You *dont ever* should conect any speaker or cabinet with an impedance less than 8 ohms to it, cause you ll pushing out of your PA more power that it can handle, so you ll probably hurt it.
Power[w]=Tension [v]* Current [a],  and Current = Tension / R(impedance)[ohm], so as R is lesser, I is bigger, and so is bigger P. Making R(your speaker or cabinet) leeser you ll trying to get for more power that you PA can give.
Hope usefull answer. Maybe somebody can fine tune my english and concepts.
