October 13, 2025, 03:20:51 AM
Need Help with Marshall Mosfet
Started by sasnak007, April 21, 2009, 09:50:23 PM
sasnak007
I recently came to own a Marshall Mosfet Lead 100 head (model 3210) that doesn't really work, and I'm looking for any assistance I can get.
Basically, when I plug in the amp just hums. If I crank up the master volume, I can hear the guitar very faintly. Moreover, if I move the springs in the reverb unit, the sound comes through the speakers loud and clear. Also, if I plug into the effects loop return jack, I can hear the guitar fine (just can't use any of the controls and whatnot).
I've checked the solder points (went over a few just to be safe) and looked for any grounding issues. I thought it might have just been the input jack (grounding problem or something), but that doesn't appear to be the problem. I checked the voltages, and as far as I can tell, it all appears OK.
Sorry to rant, but I'm really in need of some help from someone with a little (or a lot) more experience with amp repair than me. Please, if you have any suggestions or might be able to help me at all, I would really appreciate it.
Thanks!
Looks all the way like a defective Loop return Jack. Test it by hooking a known working good guitar cable from send to return jack, and your guitar up front, it should work.
If it does, just play it safe and replace both of them.
