May 23, 2024, 02:17:29 AM
Bridged LM383?
Started by joecool85, February 23, 2010, 09:01:52 AM
I designed this several years ago while in college, not sure if it would work or not...but if it did it would give you 16w RMS / 32w PEAK on a 12-15v DC supply.
Hi joecool.
The left half is fine, the right one has input (+ /-) pins crossed.
It works on LM386, but not on others.
The preferred aplication, straight from the datasheet is:
If you DC balance both chips, you save two output electrolytics. ;)
I've built lots of these, they work very well.
Later I started using TDA2005 which is the same on a single chip.
The thing is LOUD on 4 ohm speakers, fed by a 12V 7A gel battery.
I make my own 10" guitar speakers just for that use.
E
Quote from: J M Fahey on February 23, 2010, 11:25:46 AM
*raises eyebrows*
I knew you could make drivers but i didn't think the art was refined enough for you to make something specialised... or even with an ounce of good sound quality?
I'm afraid I don't understand your posting.
Quote from: E on February 24, 2010, 04:02:51 PM
*raises eyebrows*
The best sounding speakers are frequently made by an individual in their basement who is fanatic about building their own speakers/gear.
E
Hmm, come to think of it the only material i've read on the subject was just concerning a man wrapping wire around a spool and taping it to a paper plate... or something similar to that. Can you point me in the direction of some please?
For starters, google "Ted Weber"
