May 24, 2024, 01:12:00 AM
Making a guitar amp out of a computer speaker
Started by spaztronic, October 06, 2009, 06:15:51 PM
spaztronic
Ok so i have a computer speaker wich has 2x3" speakers that sound pretty good and i want to add some distortion/overdrive to the circuit.It has tone and volume control and i was wondering how to add distortion to it and also by adding a drive section to it will i be able to connect it to the speaker power supply 20v or should i use a separate power supply for the drive section.Thanks
rowdy_riemer
Keep in mind that the frequency response of computer speakers will be very different than guitar speakers.
Quote from: spaztronic on October 06, 2009, 06:15:51 PM
Are you planning on using the old circuitry or making your own?  The easiest solution would be to use the case and speaker and run them with a Little Gem or Ruby 9v powered amp: http://runoffgroove.com/littlegem.html or http://runoffgroove.com/ruby.html
