May 23, 2024, 10:05:12 PM
Hybrid
Started by mensur, August 05, 2009, 06:33:17 AM
Brymus
Thanx Mensur, how about a cathode follower instead? using a small triode? one half for each phase?
Also do you have a recomendation what to use for the voltage follower instead?
mensur
Hi, you can use anything as a follower (what suits you the best), first use tubes, and if you like the sound let them in the circuit, as for SS followers you can use high voltage mosfets (with 100K bias and divider), or fet (supplying it from the PA supply).
Quote from: mensur on August 16, 2009, 09:22:43 AM
Hi guys,
I fixed the problem and here is the sample of my amp:
Ultra Sample.mp3
It was recorded with cheap PC mic.
The link isn't working for me, and I'd love to listen to it :-(
It says I don't have permission.
mensur
I repaired it, it should work now.
Ultra Sample1.mp3 - dry
Ultra Sample.mp3 - wet
Quote from: mensur on August 21, 2009, 02:22:48 PM
Sounds excellent!  TONS of gain, eh?
mensur
Thanks, yes it is super hi-gain, I like Marshall on steroids kind of amps :tu:
mensur
Hi guys,
Recently I worked on the amp, and there is no more sizzle,hum,brum or anything...so I made a new clip:
Memmara Hi Gain Ultra.mp3
It's stereo, on the left is modern hi gain tone, on the right it's hi gain marshall mid tone.
Tell me what you guys think?
Can somebody tell me what would be the values for the blackstar amps tonestack with ISF?
mensur
