June 03, 2024, 06:34:19 PM
How can you tell if a capacitor needs replacing?
Started by posegate, August 14, 2009, 04:18:34 PM
posegate
Hi Posegate, your question is *very* generic, the answer must necessarily be so:
*every* component is there for some reason, it must "do something".
If you know that it´s nor doing so, either marginally or catastrophically, then it must be replaced. Anyway you should try to find why that happened.
posegate
What I mean is, what symptoms would an amp produce if, for example, the filter capacitors needed replacing?
Brymus
It would have way more ripple and hum and sound farty and loose.
posegate
So if volume/gain (is there a practical difference?) were strictly the problem, what should I look at?
Hi posegate,
                 Would be better if you just explain the symtoms you have noticed
and then you might get closer to fixing the problems you are having.
Cheers Phil.
Brymus
#6
Quote from: phatt on August 18, 2009, 10:44:42 AM
Hi posegate,
Cheers Phil.
Hi phatt sorry to hijack thread but are you ZP? zaphoid phil from Canada?
If so you have helped me in other forums  8)
Quote from: Brymus on August 19, 2009, 03:42:52 PM
Hi posegate,
Cheers Phil.
Sorry not me,, I live in Australia, 'an I've never been OS,, but hell yeah Canada sounds/ looks like a nice place to live.
posegate
The main issue is that there is very quiet.  I replaced the speaker, which helped a little, but there's still little gain.  I have everything cranked to 10, and still can't hear it above an acoustic guitar.
