May 22, 2024, 10:19:50 PM
Tech 21 Power Engine
Started by jmdfd415, February 22, 2007, 07:19:37 PM
Hi Zappacat.
To begin with, I fully agree with all of Teemu´s suggestions.
I told you to search for the "zillion" Gainclone projects, or LM3886 projects, which of course use a PCB and all necessary components, to save you the chore of designing your own PCB.
I pointed to the "minimalistic" one for you to see just how simple it might become, compared to the LM4780 and its close spaced pins, but of course I agree that a guitar amp, specially a "combo" type , mounted inside the very speaker box, gets handled roughly and should be built sturdily.
You can use the GGG project as a guide.
http://www.generalguitargadgets.com/pdf/ggg_lm3886_amp.pdf
Not the best in the world, but, hey!, it´s free!
It follows exactly the manufacturer´s recommendations, http://www.national.com/mpf/LM/LM3886.html  including the non-use of a Zobel network.
Personally, that makes me nervous; I´d add a .1 ceramic in series with a 4,7 ohm 1/4W resistor from pin 3 (output) to speaker ground.
I´ve searched a lot,it seems that everybody and his brother is offering 3886 kits, but of course nobody posts the PCB design.
If you dare to design your own, go for it.
Yes, I suggest you build two 3886 amps instead of one 4870.
I think it will be easier to get 8 ohm speakers.
Yes, most (¿all?) the stuff published refers to Hi Fi amps, and minimalistic by the way, not guitar amps which get a rougher treatment.
I´m not at home now, later I´ll draw and post a rough sketch of a "guitar version" 3886, including all of Teemu´s suggestions.
Bye.
Zappacat
Quote from: J M Fahey on May 06, 2009, 10:05:18 AM
Hi Zappacat.
Bye.
Can I power two 3886 chips from a single transformer or will I need two transformers?  I'm really looking forward to your sketch.  Thanks for the help.
One transformer (so long as it's large enough) will power two LM3886s no problem.  In fact, Brian at chipamp.com has a kit designed for that type of use.  He's a good guy and his PCBs are really high quality.
