May 23, 2024, 07:04:06 AM
HELP!!! Marshall Valvestate....
Started by filiphslim, August 12, 2008, 12:27:32 PM
filiphslim
My first post in this forum  ;D
Well, this is my situation...
I bought this Marshall Valvestate S80, 40 watts (model 8240), from a friend today. I got it pretty cheap because we knew that it wasn't in it's best condition.
Anyways, directly when I turn the amp on, I get a loud buzz/hum or whatever you could call it. It's there even when all the knobs are turned off and I tried all the buttons but it won't go away.
One really wierd thing is that the buzz seems to be in the key of G (?!), so when I play some licks or whatever, in G, they sound better than it does in any other key.
My friend telled me about how it first got there. I wasn't there when it happend so I'm not entirely sure but this is what he said happened;
He just got it, but I think it was from the 90's or something, turned it on and it played really good, then he put on some reverb. But he was rehearsing with his band so I guess he took the volume all the way up. Then he took his (dist?)pedal between the amp and the guitar but when he turned it on he heard some kind of sound/pop/boom, I don't know. And after that, it sounded really wierd, kind of like it does now, I guess. But then when he switched to the clean channel it was all good.
The next day when he turned it on though, it sounded just like it did when the accident had happened the day before and with the really loud hum/buzz.
I have changed the tube to a new one and I believe that the sound is improved but with that buzz it's hard to even hear it.
But what could be the cause of this buzz? Broken/burnt ground, bad transistor or some cooked component? Well, I don't know..
I'm sorry for this wall of text, but does anyone of you have an idea what could have happend and if there's any way to make it work good again, what would it cost?
Basically, how can I get rid of the bad sound and the really loud buzz, which comes directly when I turn the amp on?
I want all of your thoughts/ides that can help me in any kind of way! Thank you very much!
Most likely a failed power supply capacitor.
filiphslim
Quote from: teemuk on August 12, 2008, 01:50:26 PM
Hm, is this anything that I can fix by myself, if so what would it cost? Or should I just take it to a tech?
If it's the capacitors, it's a cheap and easy fix - IF - you have the skills to do it. If you don't, you pay for the services of someone that has the required skills. What people often don't seem to realize is that techs don't charge for parts, they charge for their know-how and work. And quite frankly, if you really have to ask questions like this then I think taking the amp to service is the best bet. An inexperiend person can quickly turn an inexpensive repair to an expensive one, or at worst to something repairmen don't even want to lay their hands on.
Jack1962
Teemuk is right, as usual, if your not familiar with electronic repairs take this to a tech(Service Center).
                                           Rock on
