May 24, 2024, 10:54:52 AM
Lab Series L3
Started by jman, July 10, 2019, 09:33:46 PM
jman
Can some one tell me how to set the bias on a lab series L3 Amp.
I can't seem to put my finger on the L3 schematic.
If it is anything like the L5/L7, then the bias is fixed.
3mv across any output ballast resistor.
http://www.rru.com/~meo/Guitar/Amps/Lab/schem.html
edvard
Try this:
https://mega.nz/#!1ph3CSrY!44oxSuZl6oZOZnnXJ12ikMNFncLJ2-AqZqEFzqUrnKg
Interesting schematic, that L3; it uses a CD4007 strung up to use the top half of it's 3 inverters as P-MOSFETs running the tone controls and another for the reverb driver/master out.
I don't see anywhere that counts as adjustable bias, but I could be wrong...
Nice find on the L3 schematic, PE.
It appears that R9 is a variable resistor for idle current adjustment.
Measuring the voltage drop across R16, 0.22 ohm ballast resistor, will give you your bias voltage.
jman
Thanks for all the info.
