May 24, 2024, 06:45:31 AM
Capacitor conducting DC?
Started by flester, December 14, 2017, 09:24:10 AM
flester
Just troubleshooting an LM386 amp build on veroboard very similar to the Ruby Amp on runoffgroove.com. (it worked on breadboard!) when i do a continuity test one of the capacitors seems to conduct. Is this normal or does it indicate a bad capacitor? Its 100uF electrolytic.
Sent from my SM-G935F using Tapatalk
The only 100uf cap on the drawing is for the battery.
What problem are you troubleshooting?
Katoda
When tested with an ohm meter, every capacitor will conduct for a short period of time, depending on the RC charge time. R being the internal resistance of the ohm meter. If it conducts continuously, the cap went bad.
flester
Quote from: Katoda on December 14, 2017, 12:03:10 PM
Thanks all. I just had no output or even a click when powered up. To be honest it ended up a mess with broken copper strips etc as I'm new at this. Just going to start again and use 8 pin socket instead of soldering chip to board. Have spares for all the parts anyway.
