May 26, 2024, 12:50:56 AM
Ibanez TBX150H got real quiet
Started by blickfang, December 30, 2013, 04:06:48 PM
blickfang
Hi all
I have Ibanez TBX150H and use it sparingly these days.  For those not familiar, it is a discontinued solid state head.  I thought I would play through it the other day and I mixed up my send and receive cables on the effects loop.  I usually power it off before I do that but I was in a hurry!  after doing that I lost all power it had.  I can hear guitar but only faintly.  I am waiting for Ibanez to offer me a viable solution. I think something happened to the power section.  Is there an easy way to tell?  If I did blow it up and it needs to be replaced, could I use a more powerful one?  It was a great sounding amp for a SS, but could not keep up in the volume department.
Thanks!
Start by plugging a known good cable from send to return jacks.
Report results.
blickfang
Hi  J M Fahey
Just so I am clear:
plug one end of a good cable into the send jack and the other end into the receive jack.  Have my guitar in the guitar jack......correct?   :)
gaioshin
Yup! It's generally to eliminate the possibility that the effects loop sockets themselves may have oxidised/shorted.
blickfang
I got home and plugged in a cable as directed and it came back to life :dbtu:
Thanks!  Now how do I keep it that way?
  Sometimes just giving those jacks some exercise will fix the problem.  Plug your cable in and out of those jacks a dozen times or so, see if that helps.
Usually you also need to spray some contact cleaner in them (something like deoxit or nu-trol) as well as exercising them to work the cleaner in.
  The other option is to just leave a short patch cable in there.
blickfang
Thank you guys for the quick responses.  I will try the Deoxit plan this evening  :cheesy:
There is great wisdom in leaving a short cord plugged in,,, I'd take G1's advice before wasting money on cleaning stuff. These sockets are cheap and nasty and will fail again in the future. xP
blickfang
The deoxit plan was a success!  Thank you very much for your help and expertise  :dbtu:
blickfang
Hey Guys
Quick update.  Yes the amp works with nothing in the effects loop.  When I try to add effects it goes back to sounding like crap.  I will probably have to replace the jacks.  but not now.  Thank you again for your input
blickfang
Hi There
turns out the amp is still under warranty.  I am going to send it out.  Thanks again for the input  :dbtu:
